Buschur Mustache Bar install
Old Mar 31, 2008 | 11:22 AM
mithrandir7533's Avatar
Has anyone else had difficulty with this install. I'm wondering if my difficulties may have come from an incident with a curb which resulted with a few rear suspension parts being replaced. Basically, I had to remove the subframe alum part and line up one side for the subframe connection (alum bushings) and then work in the other subframe connection. I then attached the subframe and bolted the mustache bar to the rear diff.
Anyone one else have an issue with the two subframe connections not aligning up properly?
