Got my PPI ported coated hotside :)
Old Apr 1, 2008 | 09:23 AM
shunderwunder's Avatar
I got my PPI ported coated hotside the other day & I'll have to say it looks great. The quality apears to be top notch. Thanks PPI. here are a couple pics.
and a pic with its new friend
Old Apr 1, 2008 | 09:46 AM
C6C6CH3vo's Avatar
Nice, how much was taken from each chamber?
Expect increased boost creep if a good amount was removed. The larger area will increase backpressure and decrease velocity near the WG but this can be overcome with stiffer preload. Especially on a standard IX turbo so keep an eye on the backpressure.
Thanks for posting the images
Old Apr 1, 2008 | 10:32 AM
Aby@MIL.SPEC's Avatar
can you explain how you came to this conclusion?
Old Apr 1, 2008 | 10:40 AM
RevMoto's Avatar
They really don't take off much. Not just them but everyone. Not much to take off in the hotside anyways. Looks good though.
Old Apr 1, 2008 | 11:58 AM
PPI's Avatar
PPI
Thanks for the compliments Shunderwunder! I am glad you are happy with our work!
I have seen more than a few manifolds and hotsides ruined by people not knowing what they were doing....
That o2 setup looks nice. It should scare the innocent bystanders
Old Apr 1, 2008 | 12:22 PM
rr06rs's Avatar
question about the dump tube. Is the inside of the o2 housing welded up so that the exhaust side is completely divorced from the wastegate side? I've always wondered if people running these external dumps leave the hole inside of the o2 housing because my only problem with that is the fact that it's going to be a constant exhaust leak even when the flapper is shut. I don't think I'd care too much for that. On another note though, you could have one custom made that would be pretty badass if you ran a full 3" exhaust side discharge from the flange and then a straight dump tube off of the flapper side.
Old Apr 1, 2008 | 12:42 PM
RevMoto's Avatar
Actually very hard to ruin a manifold.
Old Apr 1, 2008 | 01:02 PM
PPI's Avatar
PPI
Actually, no its not....
Many people "think" they know how something should be ported for best flow....I am not even going to get ino it.
Old Apr 1, 2008 | 02:01 PM
C6C6CH3vo's Avatar
I never came to this conclusion, just know it's a fundamental law of physics. For more specific info on the topic: "Application of Turbochargers in Spark Ignition Engines" by Wallace William Bester, specifically 3.3.3 and on.
Also, “The passages so formed have an increasing cross-sectional area as the fluid moves through them, the kinetic energy of the fluid being reduced, while the pressure energy is further increased”.
Old Apr 1, 2008 | 02:45 PM
Jeff_Jeske's Avatar
Never did see those dyno results from .....
https://www.evolutionm.net/forums/sh...d.php?t=326278
Old Apr 1, 2008 | 03:58 PM
justboosted02's Avatar
can you explain how a stiffer preload on the wastegate decreases boost creep?
Old Apr 1, 2008 | 05:37 PM
It is welded shut internally. they are 2 separate pipes. There are pictures of it at the end of the first page of this thread.
https://www.evolutionm.net/forums/sh...d.php?t=330022
Old Apr 3, 2008 | 06:26 PM
Old Apr 3, 2008 | 07:38 PM
RevMoto's Avatar
The car that had the manifold got smashed before it could have been dynoed. He is getting another one though.
Old Apr 3, 2008 | 07:41 PM
RevMoto's Avatar
Explain because I know I have done my testing. Never seen any from you guys. Not saying you do bad work but porting is not rocket science.
