Tranny Alignment
Old Apr 6, 2008 | 06:44 PM
SpeedJunkyz's Avatar
Tranny Alignment
Ok I did the clutch in my car and for some reason the tranny shaft has moved and now the teeth wont line up to the disc teeth of the clutch. Any ideas On how to get this thing to line up without having to remove the tranny.....cause you know it was a ***** to get in there...on my back....
Old Apr 6, 2008 | 07:24 PM
MRfabolous's Avatar
do you mean the shifter is difficult to get into gear ?
Old Apr 6, 2008 | 07:28 PM
No the actual shaft on the tranny isnt going into the clutch disc.....Im intalling the tranny
Old Apr 6, 2008 | 07:29 PM
2theMAX's Avatar
You may need someone on the other side turning the crankshaft slowly while you are pushing the clutch on. As long as you used an alignment tool when installing the clutch, it should go on just make sure to have the spline level when you push it on.
Old Apr 6, 2008 | 07:35 PM
The other axle is out.... and this thing isnt the lightest... I need to work out first 5.7 buck 40 lol Im a small guy.....
Good idea too I will try it out the best I can
Old Apr 6, 2008 | 07:36 PM
dogbox2's Avatar
You want to get someone to turn the crank with a 1/2 ratchet while trying to align the input shaft of the tranny..
Old Apr 6, 2008 | 07:43 PM
Originally Posted by dogbox2
You want to get someone to turn the crank with a 1/2 ratchet while trying to align the input shaft of the tranny... I think that is what he meant not while putty the clutch on..
That helps too, But I knew he meant tranny.......Anyone wanna fly down and help haha
Old Apr 6, 2008 | 07:49 PM
dogbox2's Avatar
If i was closer I would give you a hand..I know that sometimes these clutch changes can be a pain..I have did my fair share..It surely helps having 2 people when putting the trans back in.. Good luck
Old Apr 6, 2008 | 07:56 PM
How about I give you free room and board and beer? lol..........The place I work at has a guest room.....Ill pay for it........you come down pop it in with me and DONE....lol
Old Apr 6, 2008 | 08:07 PM
dogbox2's Avatar
I will more than likely be putty a trans in tomorrow.either in an evo or hopefully a 2g because they are way easier. So I am going to have to run...Hope everything works for you....
Old Apr 6, 2008 | 08:12 PM
I take that as you will think about it...ill be here....
liass44
11
Nov 18, 2016 07:05 AM
SyncdLancer
Sep 29, 2016 04:39 PM
Acuality
Jun 23, 2016 08:09 PM
Charlie-Y
May 16, 2011 07:21 PM
Reilly
May 1, 2009 10:36 AM
