Photo's of my Green install
Old Apr 9, 2008 | 04:38 AM
recompile's Avatar
This took about 6 hours... I also drained the coolant (changed to distilled) plus changed the head bolts for ARP studs. I used all new hardware and new gaskets, but re-used the oil/water lines.
No problems thus far, and the difference (even untuned) is quite huge. I'll start a different thread for the tuning & comparison of the Green to the Stock turbo as soon as I get to the dyno next week... this is just for pics & installation process.
What was changed:
Code:
Mobile1 5w-30     >>>  ENEOS 0w-50
Stock Turbo       >>>  FP Evo Green Turbo
Stock Manifold    >>>  Ported/Coated Stock Manifold
Stock Hotside     >>>  Ported/Coated 10.5 Green Hotside
Stock O2 Housing  >>>  Ported/Coated eBay O2 Housing
Stock WGA         >>>  Forge 20psi Actuator
#60 Boost Pill    >>>  #65 Boost Pill
Stock Head Bolts  >>>  ARP Head Studs
DEI Reflect-A-Cool added to all IC Piping
Supporting Mods:
ETS Intake
Helix Exhaust
Walbro FP
PTE 780cc
Nisei LICP
AGP FMIC
ETS UICP
ACT XTSS
Fidanza FW
If the pictures don't work, here's a Flickr gallery: http://www.flickr.com/photos/2368969...7604462360315/
Old Apr 9, 2008 | 04:44 AM
Sharkbite2000's Avatar
nice looking set up what size turbo is that?
Old Apr 9, 2008 | 04:45 AM
TeStUdO's Avatar
Nice. You will notice a pretty big difference. The turbo, especially the compressor and turbine wheels, are much bigger than the stock 16g.
Old Apr 9, 2008 | 05:11 AM
RyuEvoIX's Avatar
That's a comparison between an Evo VIII and Evo IX turbo. He has an Evo IX so externally the Green looks exactly the same from his 16G.
Old Apr 9, 2008 | 05:14 AM
TeStUdO's Avatar
If you read my post, I was pointing out the diffence in the wheel size, not the compressor housing size.
Old Apr 9, 2008 | 06:36 AM
bolsen's Avatar
awww how cute
Old Apr 9, 2008 | 08:54 AM
TurboRSX04's Avatar
Originally Posted by bolsen
awww how cute
lol
Old Apr 9, 2008 | 11:49 AM
Aby@MIL.SPEC's Avatar
why are you using that crappy hardware on your turbo?
i hope you used plenty of antisieze, as that hardware will become 1 with that hotside after several heat cycles....
i apologize for being harsh, but you'll be more pissed at yourself down the road when those butter bolts break in your hotside.
Change that out if you can asap with oem stuff.
The cost for all new oem hardware is less than the cost of having 1 threaded hole repaired down the road...let alone the hassle of removing everything in order to get it repaired.
just order the oem hardware from san rafael mitsu or mitsubishi.com...
nice pics
Old Apr 9, 2008 | 11:53 AM
recompile's Avatar
Everything's anti-seized of course
Old Apr 9, 2008 | 01:38 PM
PPI's Avatar
PPI
All I see are red x's....
Old Apr 9, 2008 | 01:45 PM
recompile's Avatar
The images are hosted on my not-so-friendly web server.
Here's a link that should work: http://www.flickr.com/photos/2368969...7604462360315/
Old Apr 9, 2008 | 01:54 PM
PPI's Avatar
PPI
There they are . Looking good!
Old Apr 9, 2008 | 02:31 PM
urnamehere's Avatar
nice!!!
Old Apr 9, 2008 | 02:33 PM
max2evoix's Avatar
thats a big diff in turbos..
Old Apr 9, 2008 | 02:35 PM
Mr. Evo IX's Avatar
Are you going to try for over 400 on pump? Will be interested in seeing your numbers shameless. Cam plans?
