Max power with evo 9 with stock turbo with mods on pump gas only?
Old Apr 15, 2008 | 05:07 PM
  #31
wshihdnevo's Avatar
werd
Old Apr 15, 2008 | 05:28 PM
  #32
syktek's Avatar
my IX did 371 @ 23/24psi on 93oct. (Ivey's dyno), best trap so far has been 117mph with coming out of first early due to bad wheel hop :\
Old Apr 15, 2008 | 05:40 PM
  #33
assembeldbygod's Avatar
What mods do you have?
Old Apr 15, 2008 | 05:47 PM
  #34
syktek's Avatar
tbe, o2 housing, fmic, cams, fuel pump, mbc, intake w/ 4" k&n, act clutch, other misc non-power mods
Old Apr 15, 2008 | 05:52 PM
  #35
wshihdnevo's Avatar
^Thats about right.
Old Apr 15, 2008 | 07:05 PM
  #36
LilRico's Avatar
Originally Posted by RevMoto
Not if I beat Rico to it first.....
Go for it bro.. I'm taking my time for something nice
Originally Posted by Jeff_Jeske
Dyno numbers are worthless and pump gas can mean anything from 110 leaded to E85.
Pump gas to me means 93 octane to 91... But that's just me... E85 or E anything, 100+ octane = race gas to me...
Old Apr 15, 2008 | 07:10 PM
  #37
wshihdnevo's Avatar
truth.com
Old Apr 15, 2008 | 09:45 PM
  #38
RevMoto's Avatar
I am just talking ****. You already have the power. I am definitely a solid 380 car right now. That's without the external wastegate sitting in my garage. Waiting on the wideband.
Old Apr 16, 2008 | 10:15 AM
  #39
Jeff_Jeske's Avatar
I think most 9s would trap better if they had the 8 fourth gear.
Bouncing off the rev limiter in 4th kinda reduces the mph to hp estimate.
Old Apr 16, 2008 | 10:22 AM
  #40
RevMoto's Avatar
Yea but if you have springs and retainers you can rev higher and raise the limiter. Cheaper than a 8 4th gear.
Old Apr 16, 2008 | 10:23 AM
  #41
syktek's Avatar
i just went with an evo8 4th from shep...haven't been out to the track yet this season, hopefully soon!
Old Apr 16, 2008 | 10:26 AM
  #42
LeosEvo's Avatar
Originally Posted by MentalEvolution
481whp 455tq. . .although not sure if its on pump
http://www.youtube.com/watch?v=rMTo_y6Yihk
this is the actual record of the most power on an evo 9 turbo but it was on E85....
Old Apr 16, 2008 | 10:55 AM
  #43
RevMoto's Avatar
Yea that doesn't go for what the OP is asking. Straight pump. Right now Rico owns the show. I am in third by 1 hp from last dyno but I just gained 10 and about to gain another witth my external wastegate. I am also on stock cams with JUNS on the way. I am pretty sure that will put me second on the list. A lot of people have made more but the dyno sheets can't be taken seriously.
Old Apr 16, 2008 | 11:52 AM
  #44
LilRico's Avatar
I don't want to get into a pissing match or anything like that, but I have looked at a lot of dyno charts and something isn't "normal" for some saying they have made over 400. If there's a 400+ HP EVO on pump gas, then that's great, more power to them, but looking at the dyno's and more importantly looking at the 5252 mark, something seems "OFF". I have tried my hardest researching and trying different combinations of parts and I am using what on my car works best... Having just a TBE, Intake and a few mods will not yield over 400 AWHP, your car has to be set-up right. I am currently running my car on stock cams... Though my car is a beast as it sits, it's not as powerful as it was with Cossi cams.. You need a great tuner to have your car running perfect, but safe.. My car has not seen AFR's in the 12's, that's not something I do at all, but target more of a 11.5 AFR.
Like I said before:
Pump gas = 91 - 93 octane fuel.
I've been PM'ed and asked a million of times how to get "close" to 400 AWHP and it's really easy:
*TBE
*a good set of 272 cams (to help with low down torque and high end HP)
*LICP
*Fuel pump (The IX stocker allowed me to make 37x so take that with a grain of salt)
*UICP (I didn't find any difference with it. but the straighter flow I'm sure by common sense adds maybe 1 or 2 HP... Nothing big though)
*O-2 housing... (This is where I'm thinking of changing.. I want to test my ported vs a O-2 dump tube.. Should be very interesting to see)
With that alone you should be very close to 370-380 mark depending on how well your car takes mods...
okay, well enough about that, I'm just blabbin now, back to the thread...
Old Apr 16, 2008 | 11:54 AM
  #45
ID #376's Avatar
My EVO IX made 406.37 WHP and 411.75 WTQ at 25PSI on 93oct
Attached Thumbnails Max power with evo 9 with stock turbo with mods on pump gas only?-2008-04-16-1439-48.jpg
