Suman's Revenge - 685 whp on BR cast kit with FP GT37HTA (I was wrong)
#31
a couple of notes... THis car has two mufflers... Wiseco Pistons with upgraded wrist pins and Brian Crower Pro Series Rods with ARP 625+ custom age rod bolts. Cosworth bearings. ARP bolts, balance shaft removed(thanks Chris and NOLIMITMOTORSPORTS for the parts) as far as the whole motor build is concerned. The head has Supertech dual spring set.
S
S
#32
#39
We are installing the second alcohol jet today and doing a re-trq on the head etc.
I will be returning to the dyno later tonight at around 11 pm as today is very hot out (over 70) and attempting to crack 700 whp
We'll see what this beast has in store.
My suggestions for Suman
1 - Driven Innovations Intake Manifold with Ebay T/B
2 - More agressive cams
3 - Buschur exhuast manifold and 02 housing with T3 Garret back housing and V band outlet
With those changes I feel this will be a high 600 whp reliable pump gas car and get into mid 700's on race gas
For reference the Shark Bite 2000 Evo was on the dyno directly before Suman's car (within a half hour) and in same conditions on C 16 at 41.9 psi max boost made only 675 whp.
Al on George's station
#43
