what is wrong in this picture?
Old Apr 19, 2008 | 07:43 PM
JC evo1's Avatar
Originally Posted by 9sec240
It happens. Dig around with a magnet and find the rocker. If the cam lobe only has a slight score in it, pop a new rocker on it and boost away.
I have seen 4gs with way more cam damage that run like tops.
I wouldnt tear the motor apart yet.
yeah i found the rocker, it looks fine but i will get it checked out to be sure.
The motor has 30% leakdown on 3 and 4, thats why im pulling it down.
anyone know how to get the crank pulley off? i got the 4 bolts off, but it seems stuck on still, do i need to remove the 1/2 drive center one?
Old Apr 19, 2008 | 07:51 PM
2k4EvoVIII's Avatar
No you dont have to remove the 1/2 drive bolt. Just the 4. My be stuck on. If you cant get it off get a puller.
Also my guess would be he installed the cams and didnt notice the rocker was not set in properly. And once it was fired up it scored the cam lobe and then fell off.
Chris
Old Apr 19, 2008 | 07:56 PM
EvoVIIIJeremy's Avatar
+1
Old Apr 19, 2008 | 08:51 PM
quickgti18t's Avatar
can you spot the problem?
I bet having that injector turned like that doesn't help. Unless you moved
Old Apr 19, 2008 | 10:49 PM
ChuckP's Avatar
Old Apr 20, 2008 | 01:16 AM
JC evo1's Avatar
so i got the head off, there is some piston damage on the crowns near the vavle recess, it looks like they have overheated and chipped off.
Old Apr 20, 2008 | 12:30 PM
2k4EvoVIII's Avatar
Can we see pictures of the bottom of the cylinder head. Probably can get a better idea.
Thanks
Chris
Old Apr 20, 2008 | 03:31 PM
BiFfMaN's Avatar
yep seen that before.....the lean ping.
Old Apr 20, 2008 | 05:36 PM
JC evo1's Avatar
Thanks
Chris
Old Apr 20, 2008 | 07:17 PM
Originally Posted by ChuckP
look at the 1st one, If it ran like that im sure it can cause problems.
Old Apr 20, 2008 | 07:31 PM
2k4EvoVIII's Avatar
I dont think it would cause a problem at all IMO. The injector doesn't have to be perfectly aligned (so to speak) A clean injector will have a even spray pattern no matter how it is installed.
Chris
Old Apr 20, 2008 | 10:24 PM
JC evo1's Avatar
the injector is fine like that, besides thats the least of my problems
Old Apr 22, 2008 | 05:01 AM
JC evo1's Avatar
so i got the pistons and rods out, can anyone identify what brand rods these are? Possibly Argo?
Old Apr 22, 2008 | 02:55 PM
JC evo1's Avatar
bump
Old Apr 23, 2008 | 04:06 AM
JC evo1's Avatar
anyone know?
