BF 272 Cams STOCK ECU!!! Video Clips
I raised the idle some and it seems fairly solid, only issue is the vacuum is very low and quick clutch in and the car wants to stall but I am working with Mellon on that.
http://www.youtube.com/watch?v=KYW_tX37Mdc
http://www.youtube.com/watch?v=8dqz94hWQ-Q
Thanks Buschur!
Thanks Buschur!
Excellent! Keep us posted... I'm interested to see how this turns out to run for you.... I know those are designed to be installed on stock gears (straight up) but I am wondering if the stock ecu would like them better with a bit of cam timing adjustment
Working on the tune. We have added GOBS!! of fuel to maintain 11.5afr right off the bat is was around 12.8afr. I believe my balance shaft is out and I have to get that issue solved first.
That thing sounds b!tchin'..........you could install a vacuum canister to solve the low vacuum issue. It's a pretty common problem with engines & agressive cams run on the street with high-overlap & long duration .
I have the idle high just becasue that is the way I like it. Another amazing thing is my car used to sound like a fart rocket with my old cams and with these it does not so I will be taking my bullet muffler out of there!
