35hta vs 35r vs Evo green vs 37hta
***read DB's very first sentence AFTER the FIRST dyno sheet***
link
https://www.evolutionm.net/forums/sh...d.php?t=332881
Here you go, the thread where DB tested the HTA3076, and did a minor comparison with the 35r. Thank me later
https://www.evolutionm.net/forums/sh...hlight=hta3076
.https://www.evolutionm.net/forums/sh...hlight=hta3076
Here's the dyno Graph:
http://www.socalevo.net/index.php?op...&topic=56096.0
Sorry if off topic..
^^+1 Everyone doesnt want to build the bottom end or run meth. Most ppl will stay on pump 99% of the time and ONLY run race gas every now and then at the track. PLUS if u want to upgrade the 35R will bolt up the same. i think the reg 30R's make low 400 on pump. Somewhere in the 500's on race gas. Hell and if u do decide to build the motor and keep the hta30r it will still be a beast. i can prove it....
link
link
ABy(WOT) did it.. 400+ on pump with a green 91 oct
On the 20glt with pump and stock ecu Mellon made just over 400 in DLL.
He now is running the HTA35r on pump and is making 500+ in DLL.
His story is well documented in the service/review section on this site.
The hta35r lag is overrated. I have ridden with him in traffic and it feels very close to me on stock turbo.
Hopefully next week we will have track times for his hta35r on pump setup.
i am in the same boat and can't decide...
also i have an evo 9 ...so if you that 4th gear is going to be a ***** on a bigger turbo..
i am prob going to do an evo 8 4th gear for now till i decide on a turbo..
the green would be ok...but i hate the fact that at like 80 mph in 5th in my car ,my turbo starts to spool and suck gas
i want a little lag..
+Stock Intake
+ Green Turbo ported/ coated
+ JUN 272's, JUN Springs, and Retainers
+ Buschur coated O2 Housing
+ Buschur ported/coated exhaust mani
+ Buschur V-band 3 inch TBE coated
+ Exedy Twin HD
+ ETS 3.5 IC
+ AMS Clutch lines (upper and lower)
+ AMS Lower IC pipe
+ 750 FIC injectors
+ Walboro FP
+ HKS EVC VI
+ Ecuflash
Next Mods 65mm TB, Ported Intake Manifold, and an Intake. ... maybe an UIP
