Tial 44mm wastegate
Old Apr 27, 2008 | 01:40 AM
TurboRSX04's Avatar
Tial 44mm wastegate
hey everyone,
i am putting my own turbo kit together and the manifold i have is made for a 44mm wastegate. i was wondering what spring should i get with the tial wastegate? also do u think the stock bov will hold 23 or 24 psi on my 35r? or should i buy the aps twin bov?
Old Apr 27, 2008 | 09:57 AM
TurboRSX04's Avatar
which spring?
Old Apr 27, 2008 | 10:00 AM
SloRice's Avatar
what boost controller?
Old Apr 27, 2008 | 10:15 AM
TurboRSX04's Avatar
i have the greddy profec spec b 2
Old Apr 27, 2008 | 10:19 AM
Babs's Avatar
the 11psi spring is typically the norm for 44mm wg's but you can go with something else more suitable for your build
Old Apr 27, 2008 | 10:46 AM
TurboRSX04's Avatar
well i will only be runnin 23 to 25 psi on my 35r. what happens if it is the wrong spring?
Old Apr 27, 2008 | 12:38 PM
TiALSport's Avatar
inconsistant boost if the spring is less than half the boost you are trying to run
if you are going to go to 25psi i wouldn't get anything under a 13psi spring
Old Apr 27, 2008 | 02:22 PM
TurboRSX04's Avatar
alright thanks!
Old Apr 28, 2008 | 07:47 AM
Str8Ryda's Avatar
which spring?
If you don't want to rely on your boost controller get a heavier spring. The heavier the spring is the less the boost controller has to work.
Old Apr 28, 2008 | 08:44 AM
TurboRSX04's Avatar
thanks. i just brought one with a 13 psi spring and see how that goes.
nuggy00
May 16, 2017 07:39 PM
Mauricio Evo IV
Dec 16, 2016 08:29 AM
Freddy302
Oct 14, 2016 05:16 PM
eisnikesb
Jan 26, 2016 04:40 PM
MasterNater
Jun 3, 2011 03:33 PM
