Do upgraded cams change
Old Apr 29, 2008 | 07:46 PM
ant_turbo's Avatar
Do upgraded cams change comperrsion test numers?? The reason I ask is I'm checking my buddys comperrsion right now.. and the numbers are low from before stock cams..
evo_9 coss cams....
Old Apr 29, 2008 | 07:49 PM
scheides's Avatar
EvoM Moderator
No, they should not! The valves should still seal 100% of the way, so if you *just* did the cam install, something is wrong!
Spoolin18's Avatar
The valves should be sealed.
