wierd boost leak i beleive any ideas please?
Old May 1, 2008 | 06:36 PM
IAmADirtDude's Avatar
i've checked the car up and down trying to find a leak hole lose clamp and cant find anything i guess next is a boost leak tester maybe? where can i find one and does anyone have ideas where i can look for my problem?
1st gear only maxes at 15 psi
2nd and 3rd hit 18ish and drops to 15-16 right after it peaks
4th stays close to holding boost at 19 but looks like maybe its hitting 18
5th holds 19 from what i can see while driving
im running stock boost no boost controller. jus a fuel pump, intake, tbe and tune
car only has 10k miles on it any ideas? i really appreciate any help
Old May 11, 2008 | 12:56 PM
rance's Avatar
try a different wastegate actuator. i had a similar prob on my WRX it worked for me.
Old May 11, 2008 | 01:08 PM
inco9nito99's Avatar
is it an intake pipe or a filter? within the tune were the boost tables altered at all?
Old May 11, 2008 | 01:11 PM
whoang40's Avatar
I would try to bypass your stock boost control solenoid with a MBC and see if you can boost more. Or else it could be an exhaust leak? So many possibilities.
Old May 11, 2008 | 02:25 PM
chaotichoax's Avatar
how many threads do you need?
https://www.evolutionm.net/forums/sh...highlight=leak
closed...
