a/f ratio
Old May 5, 2008 | 04:42 PM
DESERTEAGLE50's Avatar
a/f ratio
what should be the ideal a/f for my setup ?
Old May 5, 2008 | 05:17 PM
holler mcdollar's Avatar
why? do you think you're running too rich? what are you reading right now?
Old May 5, 2008 | 05:19 PM
10.1 to 10.5
Old May 5, 2008 | 08:38 PM
4TUN8's Avatar
WAY TOO RICH.
You should see something over 11s after peak boost, and it should be somewhere in the 12s ramping up to boost.
Old May 5, 2008 | 08:52 PM
recompile's Avatar
With the AquaMist kit you have, you should be able to safely run high 11 AFRs, with plenty of boost and plenty of timing.
Let me know if you'd like to start tuning that beast!
Old May 5, 2008 | 08:55 PM
srtboostin22's Avatar
i know in the srt world we tune anywhere between a 11.8 and a 12.2 evos on the other hand i heard you should be running a little richer.. so i would say a 11.5 or so
Old Jul 30, 2008 | 07:06 PM
EvoJoeIX's Avatar
im at about 11.6. thats where you wanna be
if your in the 10's, you are either untuned or might as well be untuned. thats WAYYYY to rich. i bet you get horrible gas milage too
Old Jul 30, 2008 | 07:10 PM
nothere's Avatar
I didn't see the aquamist, but you can run mid 12s easy with h2o.
Old Jul 30, 2008 | 07:58 PM
psphinx81's Avatar
im running 12.0-12.2 afrs on my setup
i run 100 octane all the time though
Old Jul 30, 2008 | 08:11 PM
MitsuJDM's Avatar
I just looked at my dyno sheet. I'm right at 11.5 through most of the pull.
Old Jul 31, 2008 | 01:14 PM
AhmadHasib's Avatar
IX at 11.5-11.8 from 3,000-7,000 RPM
Can someone also confirm if this is okay
Old Jul 31, 2008 | 01:27 PM
TeStUdO's Avatar
93 + Alky=OK
93 alone=Too lean
It should taper from 11.5
Old Aug 1, 2008 | 07:23 PM
AhmadHasib's Avatar
Originally Posted by TeStUdO
93 + Alky=OK
93 alone=Too lean
uh oh.
Old Aug 1, 2008 | 07:36 PM
M3EvoBR's Avatar
I run .78 labda on 98 oct. Ron (our 98 has 24% of ethanol on it)
Old Aug 1, 2008 | 10:17 PM
hokiruu's Avatar
10.5 is pig rich
you should be at about 14.5 idle, then very quickly dropping to 12.X under load, then 11.4ish through boost to redline. that's a little rich, but still makes good power and is safe, assuming your timing is good too
aftershock141
Jul 27, 2011 04:11 PM
5LEEPERISAH23I
Jun 17, 2010 05:16 PM
Tpayne84
15
Nov 2, 2007 12:33 AM
1 WICKED EVO
Oct 14, 2007 09:41 AM
blackonblackevo
Jun 6, 2007 11:55 AM
