Turbo upgrade gone bad
Old May 10, 2008 | 06:04 PM
Evoryder's Avatar
damn the atp kit is really that bad? even with meth?
Old May 10, 2008 | 10:28 PM
KevinD's Avatar
Originally Posted by 4TUN8
Oh btw you need to log for about 10 minutes or so before you can see LTFT.
LTFT isn't going to make a difference in power... either your rich or lean in a WOT run, thats all it takes. to get the car to idle properly and to cruise right, then the LTFT will make a difference.
Old May 10, 2008 | 10:35 PM
4TUN8's Avatar
About the LTFT I think I accidentally responded to the wrong post. Really weird. I totally understand that about the fuel trims, I don't want you to think I am an idiot.
I was reading a post about a guy that couldn't see his fuel trims and I was responding to that.......
Old May 10, 2008 | 10:43 PM
KevinD's Avatar
its all good. to many tabs open at once eh?
Old May 11, 2008 | 08:24 AM
bosco121's Avatar
Did you check for play in the compressor? Could be a blown turbo. The other thing is....what boost level did you tune for? A laggy 35r like this kit isn't going to make power until 25psi+
You've got the meth kit, push it out to 30+ and see what it does.
theres no shaft play in the turbo at all. turbine wheels and compressor wheels are fine also. we tuned for 23psi and we made 375 so then we turn up the boost and still made 375. we ended up making 394.6 at 30 psi
Old May 11, 2008 | 08:25 AM
bosco121's Avatar
ya atp kits are terrible dont ever get one
Old May 11, 2008 | 08:30 AM
bosco121's Avatar
so basically the turbo kit is no good because it is atp and im better of selling and and getting something else
bosco121's Avatar
is there anyway i can just convert the hotside to t3 and make a manifold
Old May 11, 2008 | 09:28 AM
4TUN8's Avatar
Yeah probably man. You'd probably just take the snap ring off the backside and hit it with a dead blow hammer. Then buy like a .82 A/R hotside for it...
Does it have a standard E or S cover like a true 35r does?
Old May 11, 2008 | 01:01 PM
bosco121's Avatar
its a garrett center section with garrett wheels. the compressor cover is the same as the hta 35r
Old May 11, 2008 | 08:41 PM
bosco121's Avatar
where can i get a .82 a/r hotside i want to make sure i get the right one
Old May 12, 2008 | 04:01 AM
supersal's Avatar
Originally Posted by bosco121
i know there not the best kit but i got it for a pretty good deal (so i thought). it is very laggy and the turbo is even ported. i think they suck to now that i had to deal with this. i would NEVER recomend this kit to anyone at all. and if you can a link to a thread on the atp kit and you post it for me so i can read a little more about them.
Well depending on weather you have a T3.63 or T3.82 exhaust housing you have a few options:
Some guys on this forum have had success with extrude honing the ATP exhaust housing and the stock manifold as one piece... (this might be a cost efective solution for you... or get a ATP Gt30R if you want a smaller Turbo. 2.3L can also help it spool faster.
or
You can get a T3 .63 Turbine housing for the GT35R and a new Manifold...
Get a Turbo shop to do some custom fab to your Downpipe and it won't be an ATP kit anymore...
Otherwise
Just bite the bullit and buy a new kit from a reputable vendor if your not keen to try and make it work...
but you have options bosco.
Old May 12, 2008 | 08:33 AM
supersal's Avatar
Missed one option - you can get a Twin Scroll manifold and a Twin Scroll Housing and try and convert your set-up to a TS 35R setup...
Old May 12, 2008 | 10:17 PM
bosco121's Avatar
or
Otherwise
I think im just going to go with a t3 housing and get rid of this atp one. i havent had luck with it now and i dont want to put anymore money into this setup. im gunna just have dan over at pruven make me a manifold. but thank you for the help
Old May 12, 2008 | 11:58 PM
RevMoto's Avatar
Definitely don't hone it out. The kit is not worth the hassle. I know a guy right now is selling an RNR manifold that will bolt up. Or to keep it simple get a t3 backhousing and go with the hafe manifold and 02 housing. Don't forget the tial 44mm. Then you will be extremely happy with the kit after.
