Radiator Problem!
Old May 10, 2008 | 05:59 PM
neweraevo8's Avatar
Radiator Problem!
I installed a 50 Trim Turbo Kit and i had to temporary take out the rear radiator fan for clearance issues! The car first seemed fine but everytime i turn off the car after a drive, the radiator starts letting out alot of antifreeze from a buttom radiator hose that points down. Is this normal?
Old May 11, 2008 | 06:56 AM
sparky's Avatar
What exactly is the clearance issue? Does the fan shroud hit the turbocharger compressor housing, or the wastegate etc.? Can your problem be solved by switching to a slimline fan, or a thinner core radiator such as the CBRD unit, or a half core radiator?
Is the coolant escaping from the radiator overflow container which has a drain hose which is routed down to the ground? Obviously your coolant system is running hotter temps. How much hotter? Install a coolant temperature gauge!
