typical post turbo charge air temps
Old Feb 16, 2023 | 10:07 AM
ViciousLSD's Avatar
Originally Posted by 240Z TwinTurbo
Instead of debating theoretical calculations just stick a temp sensor post turbo, which I have done in the past. Somewhere on this forum that data exists for the GTX3576r.
I was waiting for this comment. I'm not sure if math is 'real world'
Old Feb 16, 2023 | 10:34 AM
bn880's Avatar
Originally Posted by griceiv
you aren't correcting misinformation, you are just proving you suck at algebra. the equation you posted and the equation in post #4 are the same just solved for different variables.
Ahh, no I just misread it (didn't notice P / T swap), thanks for the clarification. (to clarify neither is solved for anything in that form, but yes)
Old Feb 17, 2023 | 11:48 AM
deylag's Avatar
Originally Posted by spdracerut
(P2/P1) = (T2/T1)^(k/(k-1))
Where the pressures and temperatures are in absolute values, and k = ratio of specific heats = 1.4 for air. After you solve for T2, divide (T2-T1) by the efficiency of compressor, so about 0.70. Then add that value to T1. That should get you close.
So for 1.4 bar of boost, (we'll say 1 bar = 1 atm for simplicity), P2 = 2.4 bar, P1 = 1bar, T1 = 295K (~71F).
T2 = ~379K. T2 - T1 = 84. 84/0.70 = 120. So the final temp is about 120+295 = 415K or 288F.
Equation solved for T2.
T2=T1*(P2/P1)^(k/(k-1))
where
T1 = 71F converted to Kelvin => 295K
T2 = Unknown
P2 = 2.4 bar
P1 = 1.0 bar
k or gamma where gamma = cp / cv or otherwise denoted as the polytropic coefficient = 1.4
T2 = 295*(2.4)^(1.4/(1.4-1))
T2 = 295*(2.4)^(.285)
T2 = 378.6 ~ 379K
Delta T = 379-295 = 84
Efiiciency of Compressor at P2/P1 = 70%
84/.7 = 120 K
T2 = T1 + 120K = 415K converted to Farenheit = 287.3 F ~ 288F
Equations were likely supplied by a Turbo engineer because they are mirrored here :
https://motoiq.com/compressor-efficiency-and-more/
Old Feb 17, 2023 | 01:45 PM
ViciousLSD's Avatar
does the intense heat from the downpipe get factored in there somewhere?
boostinjuice
20
Apr 17, 2007 06:58 AM
x838nwy
14
Aug 15, 2006 08:11 AM
akunochi
Sep 12, 2005 02:09 PM
NonEvo
Jun 19, 2005 08:51 PM
