04-06 Ralliart Engine/Drivetrain (no forced induction)
intercooler question
Old Jun 19, 2005 | 06:52 PM
NonEvo's Avatar
I intercoolers needed/useful for anything in non turbo engines. I know they are on cars with turbos, but would there be any reason to have one if you have no turbo.
Old Jun 19, 2005 | 06:53 PM
Kwman's Avatar
No
Old Jun 19, 2005 | 06:56 PM
NonEvo's Avatar
cool. I was just curious
Old Jun 19, 2005 | 07:01 PM
otter's Avatar
EvoM Administrator
To add some education to that answer - turbos need intercoolers because when you're compressing air, you're storing energy, which causes heat. When you pass the air through the intercooler, the idea is to bring that air temp down closer to the outside air temp. With a N/A vehicle, the air going in is already the same (or close) as the outdoor temp (assuming you have a CAI), so you'd be unable to use that outside air to cool it further.
Old Jun 19, 2005 | 07:09 PM
NonEvo's Avatar
thats a good easy to understand explanation. I was thinking that the intercooler made the air coolor than the outside air somehow, making it cooler than a CAI could. This is where I thought some benefit might be, but in that cause I feel like a tard
Old Jun 19, 2005 | 07:13 PM
Kwman's Avatar
Don't. Its all good man. Sorry, I should've elaborated. Good explaination though, if questions were never asked no one would ever learn. Take care.
Old Jun 19, 2005 | 07:51 PM
captain150's Avatar
It's been explained. But i'll add. Turbos compress air, compressing a gas=HEAT. Hot air is less dense than cool air (so less fuel can be mixed with the air). The turbo takes in air, compresses it, it goes into the intercooler which is like a radiator, the hot, compressed air loses heat to the outside air and then goes into the engine as a denser, cooler air. An intercooler would not work on a non-turbo car for one clear reason, the intercooler can only cool air to the temperature of the outside air. With a non-turbo car, the air it is pulling in is already at outside air temperature, so an intercooler wouldn't remove any more heat from it.
Old Jun 19, 2005 | 08:51 PM
otter's Avatar
EvoM Administrator
Thanks for adding that, I forgot to explain why cooler air is better.
weeeeeeeeee
Aug 2, 2016 12:21 AM
josh_evo9
Apr 29, 2016 08:00 AM
its2ply
Apr 28, 2015 03:25 AM
badassmotha4000
Sep 7, 2014 05:53 PM
jon527
Apr 7, 2003 10:57 AM
