Making 380WHP with $635
Old May 11, 2008 | 07:09 PM
Evoryder's Avatar
great job on power. ON a mustang dyno too? hmmm
Old May 11, 2008 | 07:11 PM
mx4life85's Avatar
Originally Posted by BluEVOIX
Did you adjust the boost directly from the Forced Performance wastegate actuator?
Damn nice numbers and power curve!
Yes, my tuner adjusted it directly from the wastegate. I have no MBC or EBC at all.
Old May 11, 2008 | 07:14 PM
Corey's Avatar
I see where this might end up going. I was thinking the same thing though.
Either way, nice numbers. Take it to the track and see what it'll run.
Old May 11, 2008 | 07:22 PM
Kemist's Avatar
starting to wonder if i've waste a couple of grand
Old May 11, 2008 | 07:35 PM
BluEVOIX's Avatar
Cool.
How much boost are you holding at/near redline?
Old May 11, 2008 | 07:49 PM
mx4life85's Avatar
Cool.
Uhh, I'd have to look, but I'm pretty sure its in the 20s. It barely tapers off at all. I'm going to get a video of it sometime and put it on youtube.
Old May 11, 2008 | 08:19 PM
RyanEvo2006's Avatar
Wow those are impressive. Makes me pretty excited now to get mine tuned to see what kind of numbers I can put down.
Old May 11, 2008 | 08:50 PM
Evoryder's Avatar
oh...and 23psi, 376whp? stock turbo? With those results...30+psi and meth...you are destined for 450whp easy on a mustang dyno.
Old May 11, 2008 | 10:28 PM
dxbevo9's Avatar
very impressive
Old May 11, 2008 | 10:36 PM
SPANKED's Avatar
Nice, very impressed!!!
Old May 11, 2008 | 10:42 PM
backcountryGSX's Avatar
that dyno is reading way high. I put down 300 with cams, full exhaust, dp, test pipe, reflash at 21psi, drop in filter, fuel pump, and throttle body...
Old May 11, 2008 | 10:51 PM
recompile's Avatar
Does "w/o test pipe" mean you're catted?
Were you ever dyno'd in stock form? You are up 160whp over a typical stock Evo and you did it on a cone filter, exhaust and tune.
I'm anxious to see trap speeds
Old May 12, 2008 | 06:26 AM
mx4life85's Avatar
Yeah, I have the stock cat pipe in. I have the ebay downpipe to the stock cat..then the rest of the ebay exhaust.
And yeah, I also have a wastegate...that was what gave me the big numbers.
And I never had my car dynoed from stock..wish I did though.
Old May 12, 2008 | 06:53 AM
Bonestock!'s Avatar
Lets see a dyno sheet. Not to be rude but maybe you have wheel hp and flywheel hp mixed up? A wastegate isnt gong to give you "the big numbers". Thats cams and or meth.
Old May 12, 2008 | 07:01 AM
nikkadanny's Avatar
sounds like the dyno reads like a dynojet or even higher, and your running the stock cat? weird
