WORKS - 93 flash + 3"UR TB
Re: Re: About dealer detection of ECU mods....
Originally posted by DavidV@WORKS
If a service tech were to attempt to find the rev limit on the car during a test drive by hammering the car to redline, that would likely give-away that something has been changed. That said, I would quickly look for another dealership to have my car serviced if I found out that my dealer techs were exploring the rev limit on my car.
-- DavidV
-- DavidV
This is my knowledge from BMWs witch also use the key with a chip for a confirmation code to start the car.
I would really like an answer on this Works?
Eric
Originally posted by shiv@vishnu
FWIW, most modern high performance cars (like the Sti, all BMWs, most Hondas, and most likely, the EVO) record max engine speed in their on-board "black boxes" which is a non-flashable portion of the ECU. This is the first thing most dealerships check when faced with a warranty claim. This is how they prove if an engine failure was caused by a mis-shift which would not be covered under warranty. I suspect the same logic will apply for detecting mods which raise the max allowed rev limit.
Just my 2c,
shiv
Just my 2c,
shiv
Enquiring minds want to know....
-- DavidV
That is really my only concern about the brain flash. Can the dealership read any logs that show the rpms or anything like that. I know for a fact vw can tell how you have driven the car by looking at past peak boosts and rpm's. I want to know if the same is true for my evo. If so, I would want the stock rpm limit on the car.
Why would you want to rev the car to 8500 to sound cool? If max power is at 6500 and it starts to die past that why rev the **** out of it? I understand that you make power up there, My NSX does the same thing it's peak power is at 7700 and rev limiter is at about 8200 so it is okay to rev it there but I think if you rev it to past the stock rev limiter you are asking for trouble, not only with Mitsu but with the car as well. No need to rev it that hard only need to work on making better use of the power and keep it around 7000 would be best because then you have 300 rpm just in case.
So, are your 2c speculation or verified concerns specific to the Evo? How does this impact your own policy on rev limits? Does this mean that we should expect Vishnu to not offer rev limit increases?
-- DavidV
-- DavidV
Take a look at the new M3's that were blowing up all over the place, they could see a missed shift and then you get to pay for the bill. That was until they found out it was a problem with there motors. I say keep the stock rev limiter. No reason to put the extra stress on the motor.
That's the big question, what's the safest RPM this engine can go to from the factory?
If I can get a few more RPM safely and reliably - I want them. Even if power is falling off, it's useful for road racing to hold a gear, or have more options when placing the engine in the rpm band. If the car is still holding power, heck yeah I want more rev, I like the mechanical advantages of gearing. The 4G63 Gurus should have a good guess what's safe to rev this engine to with our forged internals, and how many more RPM you can use by going with cams/springs/titainum retainers.
-- DavidV
-- DavidV
Originally posted by AbusiveWombat
David, no need to get hostile. A customer wanted to know if the dealer could detect the reflash. Shiv just stated that there is a black box that the techs would most likely use if an engine warrenty came up. My apologies if I misunderstood your post David.
-- DavidV
-- DavidV
Just my 2c,
shiv
Just my 2c,
shiv
Just started playing with OBD2, anyone know for sure ?
In a word, no. We have already run the Mitsubishi scan tool on the Brain flash and were unable to detect the reflash. Also, factory diagnostic codes are still accessible to the technicians, just as they were before the flash programming.
-- DavidV
-- DavidV
Is it a conclusive "...in a word no", as you have stated, or is it, in more than a word , that your not positive but you don't think so?
Do you know whether or not the EVO is equipped with tools that enable storage of datalogging information accessible to the dealer that could expose the changes in the maps as suggested by others?
Your claim that it cannot be detected by dealers is a significant selling point and needs to be answered conclusively and confidently.
If your claim is correct, I am sure that it is backed up in writing with the WORKS product warranty documentation provided at the time of purchase.
As far as looking for another dealer if your mods are detected through a redline probing test drive by service personnel ... too late for that, your foul will already be logged in the
servicce database. Enquiring minds really do want to know!
Originally posted by gtr
You mean 7300 rpms
That's our redline. Or was it 7400rpm. Dont' rememeber. Can't really find out on out tach since it's so off.
You mean 7300 rpms
David dosnt really answer questions does he?, he just kinda dances around them.
And if you respond to this one David, go back and respond to the other ones that you didnt answer first.
