6500 step not cutting it!!!
I had to have my tuner rasie my 2step!! It was 6500 and now we rasied it to 7100.... The reason why!! @ 6500 it would bog off the line... I'm running a GT3076 With a 70/63 and 272 cams...ACT 6 puck sprung and falken tires AZENIS RT-615
What do you guys think???
THANKS,,,,,
THANKS,,,,,
I am having the same issue with my car after putting in my BB 58 Trim..Cant get anything better than a 2.5 60 ft @ 6k (afraid to go any higher since I have blown my T-Case already in the past)...I cant get the car to launch properly if my life depended on it! But with my FP Green setup I was able to score 1.7-1.6 60fts all teh time @ 5.6-5.7k!
well 7100 with wheel spin takes off like a rocket///
My tuner said as long as I get some wheel spin I should be ok,
Raise your tire pressure to 45ish thatll help kill some of that traction.
That fixed my problem with the 3065. Even on 19's i had trouble launching at 6500.... i upped them from 35-45 and was getting a better launch than at 7000.
Another thing you can do is come off the clutch as fast as you can without actually dropping it versus slipping it.
Cheers!
Cheers!
Im launching fine with my step at 5750 with my gt35r, actually still spin really bad with 18psi in the tires.
are you slipping the clutch?
and how much boost are you building on the step?
