Where do you guys tap in for water temp?
Old May 15, 2008 | 10:54 AM
11secEVO7's Avatar
I've got a Defi gauge...
do you all tap in at the upper rad hose?
Old May 15, 2008 | 11:40 AM
Joshs EVO's Avatar
Well heres my deal, I have a water temp gauge too. I got the ETS SS upper radiator hose with their temp bung welded on and I have yet to have it work correctly. not to slam them but it could be my gauge.
I just bought all new gauges and I am getting that part where you actaully cut the radiator hose and put this coupler and then plug in the sensor the gauge comes with. So check back with me in a few weeks. my gauges should be here this sat and then go in a few weeks later. so check back with me.
Old May 15, 2008 | 12:39 PM
vortico's Avatar
http://prosportgauges.com/water-temp...e-adaptor.aspx
Not from Defi so I'm not sure if it would fit the sender, but it does say where they recommend putting the adapter in the car.
Old May 15, 2008 | 02:17 PM
Joshs EVO's Avatar
Yup that's the one I ordered. Like I said I ordered 7 blue faced Prosport gauges this past fri.
Old May 15, 2008 | 02:36 PM
MasterNater's Avatar
http://store.42draftdesigns.com/Lanc...or_p_6-56.html
Old May 15, 2008 | 04:39 PM
11secEVO7's Avatar
^that looks more like it!
I dont really like the idea of cutting my upper rad hose to put the coupler in
Old May 16, 2008 | 03:21 AM
Redline-Z's Avatar
Veteran: Air Force
Same one I got, they sell great adapters for the oil senders too.
Old May 16, 2008 | 06:19 AM
Tallen's Avatar
Silver Sponsor
Try putting a good ground to the sensor and see if it works. If the SS pipe is isolated by couplers, it will not be grounded. Often these sensors need the piece that they are screwed into to be grounded.
__________________
-Matt
http://www.SpoolinUp.com
Affordable COP Kits - Back in Stock!
"Performance without the Price Tag"
Old May 16, 2008 | 10:39 AM
zwickyc's Avatar
I have the 42 draft designs water temp adapter as well as the oil pressure and oil temp adapters for the Defi gauges. No problems so far.
Old May 18, 2008 | 05:36 PM
W2J's Avatar
W2J
check this out http://www.autometer.com/cat_accesso...st.aspx?pid=15. Give me a call if you need it.
Gerrard
Old May 18, 2008 | 05:57 PM
chaotichoax's Avatar
I'm a huge fan of 42draftdesigns products and the fact that they sell stewart warner gauges is a plus haha
Old May 19, 2008 | 05:24 AM
11secEVO7's Avatar
Gerrard
that's what I have....
but I hate the idea of having to cut my upper rad hose..
its already been done though..
I think I'll go with the thermostat housing tap in...seems more original and then I dont have to go ****** up my stuff..
sigh..now I got to buy another upper rad hose...
Old Jan 13, 2009 | 09:47 PM
Johnboy1065's Avatar
is the 42 draft design the right thread pitch for the defi water temp sensor???
Old Jan 15, 2009 | 04:00 AM
EvoooB's Avatar
I also have the 42draftdesign thermostat housing, have had it for 2 years and not one problem yet.
Old Jan 15, 2009 | 09:20 AM
was there any kind of gasket that you had to replace when you installed your 42 draft design housing???
I'm trying to order it ahead of time if there is...
