FYI you can pull the engine and transmission at one time. i know cause i just did it. all you need is an engine load leveler.
good luck with your build
I don't even know what an engine load leveler is, but for my purposes I needed to take the trans off in the garage anyway.
Cool info though, thanks.
+1 we pulled mine all in one. Didnt use a leveler. Just brought the bish on out.
Even put it in with the trans attached.
Quote:
Have about 3 ppl there to help you, its a close fit but it works. Saved us a bunch of time. Have it at a big angle with the trans pointing straight down.Originally Posted by 4TUN8
Now that I might do........put it back in with the trans attached to it.
Quote:
Originally Posted by staatz
Ben, you suckkk. Is it done yet?.lol
Hahah yeah right it wont be done for MONTHS.
No I'm not going to build up my TC, not until it fails anyway, plenty of people have gone 10s on the stockers, and I completely disagree about the driveline being made of glass.
i just figured if you were going thru all that work, you might as well build it up. i would do a built xfercase + trans just for peace of mind. i have a 12sec car & split my t-case on Pass Time!!! my built trans & Tilton Twin held up tho...
Quote:
No offense but with those mods it should hold up.Originally Posted by housedj
Ive made 70+ 500whp passes on stock trans/tcase.
I've probably made that on my TC....I blew the trans 2 years ago letting the car wheel hop out of the hole.
Evocrazy I see we are going with the same cams heh, what cams were in the car when you had it tuned?
i just figured if u pull it out, why not build it up? don't 1/2azz like alot of ppl when they build their cars up. do it right the 1st time & u won't have issues later.
what they didn't show everyone on Pass Time is they had me do a burnout b4 lining up to run. since i already use Advan A032R's, they stuck on the launch, everything else turned splitting case in 2 places + blowing pass side axle seal...
