HKS 272's
Old May 19, 2008 | 08:59 AM
mac214's Avatar
HKS 272's
Can someone verify if both cam shafts for an evo IX are stamped with HKS. If not, what are the other 'identifiable' stampings on the cam?
I am picking up a set of used 272s from a friend, who has quite a few other cams and what not laying around and we got what we think are the matching cams, however only one was marked HKS.
Thanks in advance
Old May 19, 2008 | 09:26 AM
evoPirate's Avatar
I would think they'd both be marked....sounds a lil fishy. Are there any numbers on the unknown cam?
Old May 19, 2008 | 12:19 PM
mac214's Avatar
I will have to check the marking on the second cam. I will probably just post up a couple pics of them when I get home.
The last thing I am questioning is the legitamacy of the person I am dealing with. He has just switched cams a few times and we weren't sure which is which at this point.
I was hoping someone had a set at home that they haven't installed yet to verify the markings on the two cams so we can figure out which are which.
Old May 19, 2008 | 03:45 PM
mac214's Avatar
Okay, here are the pics.
The first two are of the cam without the HKS. The second one is obviously the HKS Cam.
Attached Thumbnails HKS 272's-dsc02846.jpg   HKS 272's-dsc02845.jpg   HKS 272's-dsc02844.jpg
Old May 19, 2008 | 08:32 PM
mac214's Avatar
BTT, anyone have a set lying around that can verify?
Old May 20, 2008 | 12:14 AM
SixOneNine's Avatar
Both of mine has "HKS" on them. But it's for an 8.
Old May 20, 2008 | 10:44 AM
mac214's Avatar
Thanks for the reply. I was thinking they would both be marked, but we weren't really sure.
Anyone else have a set to verify on some Evo IX HKS 272's.
Old May 20, 2008 | 04:13 PM
mac214's Avatar
Btt
Old May 20, 2008 | 04:16 PM
jmelocik's Avatar
Sorry mine are both stamped also just like in the last picture. Mine are for an VIII also though. If you check the HKS website, they will have the part number there and that should also be on the cam somewhere.
Josh
Old May 20, 2008 | 04:21 PM
EvoHung's Avatar
I have HKS 264/272 for an VIII and they are both stamped with "HKS". I would think all of their cams are stamped, not just one out of the two.
mac214's Avatar
Thanks, it is possible one of the stockers was in the box we found and the other cam is just in another box somewhere.
Old May 20, 2008 | 04:26 PM
4TUN8's Avatar
My stockers have holes in them and have numbers stamped on them like your pictures. I think you got a stocker.
Old May 21, 2008 | 01:00 AM
supersal's Avatar
Thanks in advance
If I'm not mistaken the HKS MIVEC intake Cams for the IX's is made from an OEM Blank and is not stamped HKS so the only way to know for sure would be measure it...
Old May 21, 2008 | 12:34 PM
mac214's Avatar
That is interesting, I will probably just check with a vendor to make sure and if their intake isn't stamped, then I will just have to measure them.
Old May 21, 2008 | 12:41 PM
fugiwara's Avatar
why don't you Call HKS 310 491 3300
here is a picture of IX CAMS they look kind of different
http://www.hksusa.com/info/?id=3339
