Car in Neutral, let clutch out, car moves
Old May 20, 2008 | 07:41 AM
500hpOnPumpEvo's Avatar
So if you are parked, put the car in neutral, let the clutch out the car pulls a tad bit.
Not like it's in gear, you can hear the motor lug down for a second as well when you let the clutch out...
it's weird.
Old Jun 3, 2008 | 04:29 PM
STikiller.com's Avatar
what weight gear oil are you using? It could be a viscosity type movement from a thick fluid. Almost all cars when in the air in neutral will spin the tires. But to move the car, you have to have some serious rotation in neutral.
Does the car shift smooth? Im thinking maybe a bent shift fork, still engaging first gear a little bit?
Try putting the car in first gear with the clutch out...dont actually go in gear, just move the shifter up that way and see how much it takes for the car to start creeping forward, or the shifter to stop. Kind of hard to explain...but it could tell you something.
Hope this helps.
Thanks,
Travis
Old Jun 3, 2008 | 05:05 PM
nothere's Avatar
If its anything like mine, its just a nudge forward, I believe its cool oil, as driven and warm, no movement.
Old Jun 3, 2008 | 05:14 PM
roys44's Avatar
That happens on mine too during morning startup. It's a real thrill if you forgot to set the emergency brake.
Old Jun 3, 2008 | 06:05 PM
AcePitcher11's Avatar
^^ lol I agree man
Old Jun 3, 2008 | 06:52 PM
well it seams like it's a normal thing...whew lol..
2slowEVO8
Sep 19, 2021 02:14 PM
Peterxng
11
Jun 7, 2017 03:56 PM
ragyan03
Sep 12, 2012 05:58 PM
bluegsr
Feb 25, 2011 09:37 AM
Tfresh
Jan 18, 2011 01:23 PM
