How many 10 sec cars are running a SINGLE DISC clutch?
Old May 29, 2008 | 10:42 AM
PATRICK B.'s Avatar
I'm at a point where i need to find a clutch that suits my car's needs.
I know most of the popular cars on this forum w/ higher hp > 500 and tq >400 are running twins or triples.
How many of you are out there running in the 10 sec range and running a single set-up of some sort? What brand/model?
Thanks
Old May 29, 2008 | 12:58 PM
Dapper Dan's Avatar
i havnt been to a 1/4 track but my 1/8 mile times are good for a 10 sec pass.
Im running an act 6 puck extreme. It holds the power fine but i get locked out if i try to shift fast( clutch is adjusted out pretty far)
so im going to be upgrading to a twin or tripple before I go to the track next.
Old May 29, 2008 | 01:16 PM
jmartinez1170's Avatar
ACT and lock out hmmm seems like a common problem
Remember clutchs are rated by tq not hp will will be fine with a single disk. When you get to the point where your clutch is only lasting so many passes thats when you upgrade to a twin disk.
Old May 29, 2008 | 09:50 PM
evotris's Avatar
Really on stock ECU ?
Old May 29, 2008 | 10:29 PM
Sales@ACT's Avatar
It's as common a problem as guys who stalk every thread where ACT is mentioned.
Old May 29, 2008 | 10:33 PM
alan678's Avatar
Old May 30, 2008 | 12:18 AM
Flyin EVO 2's Avatar
Once you switch to a twin disc you'll never look back. Yes there noisy vs. a single, but being able to shift as fast as you want without plowing your clutch pedal thru the floor is worth the noise!
Old May 30, 2008 | 12:25 AM
tumtum411's Avatar
know lie i live in ny i heard of dapper dan before do u really have a website
Old May 30, 2008 | 12:28 AM
Billy@EnglishRacing's Avatar
goes with the twin, the noise is not bad at all and they are rebuildable
Old May 30, 2008 | 12:34 AM
Dapper Dan's Avatar
I love ACT clutches, I never have problems with it on the street. It just doesnt like the track. I dont think it likes my 9k shifts lol...
Old May 30, 2008 | 01:01 AM
CA$H's Avatar
The ACT Extreme 6 pucks lock out NOT the ACT heavy duty. Yes the ACT HD is a cheaper clutch but its a better one. (go figure)
I know Meth powered 35Rs running ACT HD with no issues.
Talk to TTP Engineering. He will confirm this.
IF you can't afford the Exedy Twin The ACT HD clutch kit is the next best (smartest) move.
Old May 30, 2008 | 01:45 AM
Dapper Dan's Avatar
Ive used both the hd and the xtreme with both street disks and puck, they both have lockout issues shifting at 9k.
unless Im granny shifting like hell.
Old May 30, 2008 | 02:16 AM
dxbevo9's Avatar
So Dapper Dan...you shift at 9k on the stock rods and internals?
Old May 30, 2008 | 03:05 AM
Twister4g63's Avatar
do yourself a favor and buy at the twin disc instead of a single disc clutch.
they may be more expensive, but worth it.
I've went through 3 or 4 different ACT clutches before I got my twin disc.
the pedal effort is way better and you don't have to worry about lockout.
Old May 30, 2008 | 06:46 AM
Jrod@Buschur's Avatar
This man speaks the truth!
THE HECK WITH A SINGLE DISC CLUTCH! Multi-disc is where its at.
The noise isnt even that bad and normally is only heard when pressed in.
