Boost problem after clutch change
Old May 29, 2008 | 01:02 PM
raidokoiv's Avatar
I change clutch and now boost run only 13psi.All vacuum hoses looks okey.I dont know whats wrong
Old May 29, 2008 | 09:13 PM
TurboTim06's Avatar
are the vacuum lines in the right locations? boost solenoid damaged?
Old May 30, 2008 | 12:10 AM
raidokoiv's Avatar
this is mystic.i check everything and all hoses is right location and everything looks okey.maybe boost solenoid blow out or turbo failed???is this possible??
before was boost 22 psi and everything ok
Old May 30, 2008 | 03:06 AM
Twister4g63's Avatar
check all your hoses and vacuum lines. make sure there's no rips or kinks.
Old May 30, 2008 | 06:16 AM
raidokoiv's Avatar
i change today boost solenoid and now everything is ok
i dont understand how this solenoid blow out
