Transmission Bolt
Old May 31, 2008 | 12:36 PM
mac214's Avatar
Transmission Bolt
One of the bolt heads from the transmission that goes into the block was stripped. Will I be okay driving the car until I can get another bolt? All the other bolts are in and torqued down.
Is there anything I am not thinking of that could be damaged by doing this?
Old May 31, 2008 | 12:37 PM
justboosted02's Avatar
you should be fine for a short while, just try to drive the car extra gently
Old May 31, 2008 | 01:42 PM
mac214's Avatar
What are the possible consequences?
Old May 31, 2008 | 02:16 PM
fimotorsports's Avatar
the bolt head was stripped and not the threads? If that is the case you are ok as long as the rest are tight.
Old May 31, 2008 | 03:41 PM
mac214's Avatar
Yea, the threads were fine, but the bolt head was stripped and I didn't/couldn't put it back in.
All other bolts are torqued.
Old May 31, 2008 | 06:04 PM
mac214's Avatar
Anyone else? I don't think it will be a problem, but just want to make sure there isn't something that I may be overlooking.
Old Jun 1, 2008 | 06:08 AM
mac214's Avatar
Btt
Old Jun 1, 2008 | 06:14 AM
cheb evo's Avatar
OK, that is a little different. I wouldn't run around with one of the bolts completely missing. Consequences could cost you several thousand. You local Mitsu dealer should have an extra bolt....good luck
shavkatjon2000
May 5, 2016 08:25 PM
740 Turbo Brick
Feb 8, 2014 03:26 PM
mattcky
Jul 7, 2013 01:40 PM
Solarwater
Jan 5, 2012 05:41 PM
rgar
Jul 8, 2010 04:39 PM
