No Boost leak, car is boosting at 16-17psi MAX
Old Jun 5, 2008 | 11:08 AM
projekt_shocker's Avatar
Hello,
I have searched the forums for about a week now with boost issues that other people are having, but I think my problem is different from others.
My car is boosting at 16-17psi then it goes down to 15psi and holds to redline.
The car did run 20-21 psi last year just fine with a cheap ebay mbc I had on for a while, and decided to switch it off to a hallman pro rx MBC and now I have boost problems.
My car is still running with stock turbo and stock waste gate with hallman pro rx boost controller. I have hooked up the source from the turbo nipple instead of doing the BOV-method connection, all vacuum lines are also replaced with new ones. There are a few posts in doing the waste gate mod to turn a bolt/nut a couple times to up the boost, havent tried that yet but do you think that can fix the problem that i have right now? I plan to get this issue fixed so I can install my 10.5 and new o2 housing. Looking to boost my car up to 22-23psi again!
Last edited by projekt_shocker; Jun 23, 2008 at 09:12 AM. Reason: deleted mod list
Old Jun 5, 2008 | 11:44 AM
EVIL_EVO_VIII's Avatar
Try doing the BOV method, that may fix the problem.. I have mine hooked up that way
Old Jun 5, 2008 | 11:47 AM
hellcat's Avatar
Check your egr valve. The hose could be off.
Old Jun 5, 2008 | 11:51 AM
nikkadanny's Avatar
have you turned the nob on the mbc? maybe its the bov?
Old Jun 5, 2008 | 05:15 PM
IAmADirtDude's Avatar
amazes me how we all have the same problem and cant get it fixed lol aboviously common
Old Jun 13, 2008 | 09:05 AM
bump. need help to resolve this...i checked the MBC changed out the springs to stiffer one.. and called hallman to get even a stiffer spring... got that and i switched it, still no good. I havent checked the BOV or done the wastegate mod yet... been busy lately but i will try to work on it sometimes this weekend.
if you guys have any ideas to troubleshoot... lemme know.
Old Jun 23, 2008 | 09:14 AM
UPDATE: I have spent some time with my car fixing the problem and it narrowed it down that it was the Greddy Type-S bov.
The Diaphram on the BOV was torn all around at the edge. I have fixed that, and now it is holding at 25psi. turned down the mbc to 24psi tapers at 20psi redline.
I just wanted to note that so whoever runs into a problem like mine can look it up and decipher out that the BOV could also be a culprit to your boost issue.
Old Jun 23, 2008 | 09:20 AM
fugiwara's Avatar
you shouldn't go to the stiffer spring. the spring came with the hallman bc is enough for the boost you're running. why don't you put back the ebay mbc and see what happen?
Old Jun 23, 2008 | 09:46 AM
cfdfireman1's Avatar
Infamous GReddy diaphragm failure. FTMFL
Old Jun 23, 2008 | 12:18 PM
yea i will after i get home from work... its hard to find time to work on the car and be workin alot of hours. lol
i am just happy that i got my stuff fixed and now i can add some more go-fast parts and get it retuned.
