View Poll Results: Which boost controller do you recommend?
Greddy Profec B Spec II
15
44.12%
AEM TruBoost
19
55.88%
Voters: 34. You may not vote on this poll
Which EBC? AEM TruBoost or Greddy Profec B Spec II?
Old Jun 9, 2008 | 08:07 PM
  #31
Mr. Evo IX's Avatar
Originally Posted by SRT-TO-EVO
+1 I don't think the Greddy does it through RPM. The Apexi does. Maybe there's a way for it to read through RPM? But I know for sure that's not the way it comes.
your right, sry. profec e-01 is the one that has the rpm stuff. no experience with either profec.
Originally Posted by Redline-Z
What is your crack pressure setting, I am running it at 11 and the spike is 1 psi over my setting and it spools hard. I also have my alarm at 1 psi over. I have only overboosted once and it reset immediatley to wastegate pressure. The only reason I did was because I forgot to go to my B setting one morning when it was really cold. I have heard of people running like 5-9 as the CrP, I really don't see how this can help when the spring is what 11.5?
I think I ended up somewhere around 7.3-8.5 or so with 62 cold 64 hot. Have you accessed the peak hold feature or are you eyeballing the spike?
The spring pressure used to be called GAE crack pressure. This value according to AEM is supposed to be when the wastegate starts to open. 11.5-12psi is when the gate is fully open and the turbo is full spool. There are instructions on the AEM method of determining crack pressure which is why people have the numbers they do.
Old Jun 9, 2008 | 10:02 PM
  #32
Redline-Z's Avatar
Veteran: Air Force
Of course I access the Peak hold and clear it everytime I am adjusting. I bet you are hurting your spool and I can't tell you why you are spiking so high. My setup feels great at 11.
Old Jun 9, 2008 | 10:17 PM
  #33
EVOlutionary's Avatar
Another option, although much more pricey, is the Turbosmart e-Boost 2. It is a gauge style, and uses an AEM style solenoid. It can hold up to 6 boost maps, and can be wired in to control vs. RPM. You can set a boost point for every 500 rpm point, and it interpolates between the points. . .
You can use this feature to spool quickly without a large boost spike, while still holding well at higher RPM. . .
Old Jun 10, 2008 | 01:14 AM
  #34
Redline-Z's Avatar
Veteran: Air Force
Sounds like a good setup.
Old Jun 10, 2008 | 06:47 AM
  #35
Mr. Evo IX's Avatar
Redline, I bet I wasnt, and I wasnt because I was using the setttings that were right for my car. Engines, turbos, and aftermarket parts vary some from car to car, that's why things are adjustable, not to mention different temps and altitudes.
Link to AEM's instructions on setting up truboost crack pressure. If your happy with your settings .
http://forum.aempower.com/forum/inde...c,18898.0.html
Also, should be noted. I control the solenoid with my ECU now. I have rpm dependent control and closed loop correction abilities.
Fast_Freddie
Dec 30, 2016 03:13 PM
asu11
Sep 9, 2016 07:48 AM
kyoo
Site Feedback / Suggestions
Mar 28, 2013 02:57 AM
Sano
Jun 13, 2006 10:06 PM
HiHeatEVO
20
Feb 22, 2005 05:54 AM
