good turbo for the stock motor
FP Green, you can keep everything stock and just change out the turbo. Just need injectors and a tune.
If I had to do it over, I would just buy a turbo kit. Look at a 50trim or 30R. AMS, BR or ETS. Can't go wrong.
Jason
Jason
+1 on this, I have this setup and have been running in the high 400whp range for a long time now (50+K miles). Finally cranked the timing up to see if I can hit a 10 and now at 550whp. I am using E85, so if you have meth injection, I am not sure how much you can push it.
The ETS (www.extremeturbosystems.com) Ball Bearing 58 trim doing pretty good on my stock block....I made 437whp on 91 oct...514whp on VP MS 109...
I am actually curious to know how many guys have these small TS setups with the T3 .78 housings:
TS 50 Trim
or
TS GT3071R
Besides the money and the FP Green, by virtue that this setup can flow more exhaust gasses than the Stock Mitsu 10.5 TS housing it should make either one an awsome setup for the stock 2L motor...
I read elsewhere that either one of these would be the ultimate Auto-X and street setup...
Got any dynosheets?
thanks
Sal
TS 50 Trim
or
TS GT3071R
Got any dynosheets?
thanks
Sal
l8r)
Do you want lag? Do you want to eventually build the engine? What are you doin with the car?
A lot of people these days say just jump head first into a 35R. I think this may be a bit much. I think its useless to install a 35R without a built engine or plans to do so to only hit low to mid 450's. You're not using that turbo anywhere near its limits. You're getting all the lag tho, that's for sure!
I have to agree with Warr on this, green or 50 trim will easily hit your goals and be very good use of those turbos. Maybe even the 3076. If you go with the 30R, you always have the option of going with a larger 35 or even bigger down the road if you choose by just swapping turbos
I'm going to surmise that a HTA35R will hit something like 23 psi anywhere from 4100 - 4800 RPM. A lot of that will depend on your cams, intake manifold, etc. I have no experience with your cams, so it's anyone's guess, really.
l8r)
l8r)
