good turbo for the stock motor
Old Jun 9, 2008 | 10:22 AM
  #31
Ludikraut's Avatar
As much as I like the AMS VSR intake manifold (I run one on my car), if I was in your shoes, I'd wait and get my stock intake manifold ported by IndyEvo (through Buschur) and match it up to one of the WOT (Binary/mil-spec) ported 65mm throttle bodies.
l8r)
Old Jun 9, 2008 | 11:38 AM
  #32
evoPirate's Avatar
Big cams tend to give more top end then spool. Even so, a 35r is still gonna spool slower then a 50 trim, 30r or green no matter what. If you're not gonna be at or over the 500whp mark (which would be wise to include with at least a built bottom end) why not get a smaller, better spooling turbo that even then has been proven to get to the 500whp mark on meth or c16? I'm not trying to knock the 35 at all, but if your goals are 450, its overkill
Old Jun 10, 2008 | 04:24 AM
  #33
supersal's Avatar
In terms of drivability and powerband on the stock block 2L with ususal bolt-ons I would say there are only 3 or 4 real realistic choices at the moment:
- FP Green
- GT3071R
- 50 Trim BB
Maybe FP red or HTA when it comes out - Turbo Tech in the UK also make custom stock frame TD05 Turbos capable of 450+HP...
If your willing to have a bit of lag then your looking at GT3076R but bigger than that you must be willing to rev over 8000rpm to increase your powerband...
Old Jun 10, 2008 | 01:49 PM
  #34
Str8Nasty's Avatar
Originally Posted by lexat20
I luv my 3065. Finally got it tuned over the weekend on 110. Holy sheet does it move. Stock motor other than 272's and head studs
Mod list? What numbers did you put down with your 3065r on 110? What were your numbers on pump too?
Old Jun 10, 2008 | 01:55 PM
  #35
YzBrad99's Avatar
Originally Posted by evo8fate
im just lookin for a bigger turbo im around 360 whp would like to be around 450
With those mods, i would love to see the dyno sheet.
Old Jan 11, 2009 | 11:43 AM
  #36
Jarrett 03's Avatar
turbo
go with the green
evoson23
63
Nov 25, 2016 01:19 PM
bimmer777
Aug 29, 2016 08:10 AM
Boostme
18
Mar 9, 2009 06:02 PM
CarbonWorks
Nov 24, 2006 01:35 AM
