How relieble is a 500whp evo8 w/stock motor
Old Nov 11, 2006 | 06:53 PM
CarbonWorks's Avatar
I wanted to put a 35r with a stock evo 8 motor but I whanted to know how relieble would it be.
Old Nov 11, 2006 | 06:56 PM
andifidie's Avatar
Depends on the tune and fuel used. Ive seen a few in that area running saftley. Plus, you guys have the good gas up there.
Old Nov 11, 2006 | 06:58 PM
MRadjahoe's Avatar
I heard if you change your balance shaft belt then you should be good.
Old Nov 11, 2006 | 07:00 PM
Nissaka's Avatar
also how much boost are you thinking?
LimPShoT's Avatar
i am going to find out soon. Check out this thread.
https://www.evolutionm.net/forums/sh...d.php?t=233874
Old Nov 11, 2006 | 07:04 PM
93 with methonol injection and boost proberly around 28-29psi.
Old Nov 11, 2006 | 07:11 PM
Jarrett H's Avatar
I don't think you can drive the car as comfortably as u could if it was built.
Old Nov 11, 2006 | 07:13 PM
yeah I know but would it be okay for one year untill I can get a build motor.
Old Nov 11, 2006 | 07:14 PM
thatguy's Avatar
500whp is fine with the stock internals and some have over 550whp (just search around).
I think 500whp daily driver should be very reliable provided the car is tuned correctly and some failsafes are in place
ya know maybe about 6 races in that year and by the way I also put her to sleep the winter time.
Old Nov 12, 2006 | 12:32 AM
1.8t's Avatar
500whp on the stock motor is going to take its toll, so don't kid yourself.
Old Nov 12, 2006 | 12:40 AM
evo/X's Avatar
you can try it out then after it blows up you will have to forge the internals
Old Nov 12, 2006 | 01:18 AM
SKILMATIC's Avatar
there is a thread in the turbo drivetrain section of all the 500whp evos with stock blocks. Why dont you go in there and ask? Also there have been numerous evos with over 500whp on the stock block running fine. However, not too sure how long it would last.
Old Nov 12, 2006 | 06:11 AM
94AWDcoupe's Avatar
I know of two cars locally that ran 35r turbos on stock blocks. Both ran 30 psi on meth. One lasted 15k the other 25k. Both were around 475whp.
Old Nov 12, 2006 | 07:20 AM
EVEHO9's Avatar
since when is any mitsu reliable leave it stock
