Huge Hallman MBC problems
Old Jun 10, 2008 | 07:17 AM
mhgsx's Avatar
Originally Posted by tvor
Alright I will check again but I followed the hallman diagram. I have the inlet going in the side one and the outlet going out the bottom. Is that correct?
All new lines as well.
NO
I thought you said you "triple checked" your routing? (unless of course you're "bottom" and "side" are reversed from what is normally described)
http://www.hallmanboostcontroller.co...tions%20ld.pdf
Old Jun 10, 2008 | 07:43 AM
tvor's Avatar
I'm at work right now so I'm going off memory, the only way I would have them backwards is if I did that when I took it apart to clean and lube it. I'll check at lunch
Old Jun 10, 2008 | 07:53 AM
luvnish's Avatar
Sounds to me like the lines are reversed as well, the bottom nipple is the boost source inlet from the turbo, and side nipple is the outlet to the actuator.
If that doesn't work, then maybe your vacuum lines has a leak somewhere that only shows up under some pressure, causing the spiking. Change them.
Old Jun 10, 2008 | 04:27 PM
tvor's Avatar
Yeah I must have switched them around after I cleaned the whole thing out. Stupid mistake. Still that forge was causing huge issues. I still think i have a boost leak because at around 15 psi it feels like it's dead...may be the tune is off too.
Anyways I think it's working alright now.
plokivos
84
Jun 7, 2017 11:25 AM
galantman03
43
Feb 5, 2017 09:54 PM
bboy_RES
32
Jun 18, 2009 02:26 PM
TURBevO8
11
Aug 24, 2006 08:49 AM
scottatyamaha
16
Feb 28, 2004 07:34 AM
