Why Does My Intercooler Hose Keep Coming Off At The Track ???
Old Jun 9, 2008 | 02:14 PM
MitsuJDM's Avatar
Originally Posted by Greg K
get a good set of T-bolt hose clamps and/or spray a small amount of hairspray on the ID of the hose before installing. when it dries it will get sticky and keep it from blowing off.
Stole the words right out of my mouth.
Old Jun 9, 2008 | 02:26 PM
EvoBroMA's Avatar
my stock one popped off today on the way to work under low boost...
lame. getting some t-bolt clamps.
Old Jun 9, 2008 | 02:38 PM
Vapor's Avatar
I had lots of problems until i replaced the front motor mount with a stiffer one. I've found the Evo has a lot of engine movement built in to the motor mounts, and with age they flex too much, pulling the hoses this way and that. I havent had a problem since I upgraded the mount
Old Jun 9, 2008 | 03:44 PM
george3's Avatar
Has anyone else tried replacing the motor mounts for this problem?
Old Jun 10, 2008 | 06:22 AM
george3's Avatar
Is it worth it... to change all the hoses and clamps on the car?
Old Jun 10, 2008 | 10:14 AM
Ludikraut's Avatar
That depends on how annoying you think popping hoses off various portions of your intake system is. It took me three times to learn the value of better IC hosing/piping...
l8r)
Old Jun 10, 2008 | 02:19 PM
george3's Avatar
Well, I got the T-bar clamp for the I/C hose. I sprayed hair spray on it. Clamped it down tight (I thought). Took it for a test drive and it was fine until I gave it some strong throttle and the darn thing BLEW OFF again!!!!!!!!
How tight do I need to tighten this clamp? I didn't want to strip the threads (?)
Old Jun 10, 2008 | 04:16 PM
cfdfireman1's Avatar
It's because you have a total of 23 posts an didn't search. You have upset the forum Gods.
Old Jun 10, 2008 | 04:32 PM
Ludikraut's Avatar
^ LOL.
I'm not upset ... then again I don't even qualify as a minor deity.
l8r)
Old Jun 10, 2008 | 04:39 PM
MitsuJDM's Avatar
Originally Posted by george3
Well, I got the T-bar clamp for the I/C hose. I sprayed hair spray ON it. Clamped it down tight (I thought). Took it for a test drive and it was fine until I gave it some strong throttle and the darn thing BLEW OFF again!!!!!!!!
On it? I don't mean to assume you're stupid, but you did spray the hairspray IN the coupler, right? Or did you mean onto the pipe itself? Also, you want to make these pretty tight, but be careful. You can actually CRUSH the IC pipes with T-bolt clamps!
Old Jun 10, 2008 | 04:51 PM
IDRNKV8's Avatar
I cant believe this thread is still going on.........
Old Jun 10, 2008 | 04:53 PM
george3's Avatar
ON It, in it, around it...
It's OK... I'm stupid when it comes to this
That's why I'm asking you guys
Can you strip the threads on the t-bar clamp from being too tight?
If I crush the pipe, I'll just have to get another one
How long does the hair spray need to "set" ??
Old Jun 10, 2008 | 05:04 PM
IDRNKV8's Avatar
1. You can strip the threads on anything
2. Youll have to have it on waaay overtightened to crush the licp
3. Depends on how hot everything is. Here in AZ, just a couple minutes
Spray both the inside of the coupler and the outside of the licp, put it on, and crank it down pretty good. Let it sit, IDK an hour, then boost it and see what happens. You can even mark where ur cranking it to(what thread), and if it keeps comin off, tighten it up 1-2 more turns above mark till it stays on.
Old Jun 10, 2008 | 05:28 PM
george3's Avatar
Wow.
That's real good advice.
I'm gonna do that in the morning.
Thanks !!!!!
Old Jun 10, 2008 | 05:44 PM
Gary@MellonRacing's Avatar
extra stengh hair spray !!!!!!!!!!!!!!1
