Head porting. *pic inside*
Old Jun 9, 2008 | 09:10 PM
ultimatesteve's Avatar
Started porting my head and figured I would post up a few pics and see what you guys think.
Exhaust ports.
before:
After:
Intake.
Before:
After:
I havent touched the intake ports since I pulled the valves out but I dont think Im going to do much to them in fear of messing them up. I have done several V8 heads and some old VW bug heads but his is my first go at a 4g63.... Please let me know if you have any insight on this...... TIA!
Old Jun 9, 2008 | 09:30 PM
JDMCT9MR's Avatar
Looks great man!
Old Jun 9, 2008 | 09:37 PM
2k4EvoVIII's Avatar
I can see pocket porting under the valves and porting the exhaust ports but the intake ports are just way to risky IMO. Tons of research goes into perfecting the ports finish, shape, size ect... to make optimal flow. Hopefully you are okay though.
On the exhaust ports make those things shine like glass. The smoother the better.
Chris
Old Jun 9, 2008 | 10:02 PM
yeah I didnt really change the shape or size on the intake port.. Just smoothed out the slag
Old Jun 10, 2008 | 01:25 AM
RevMoto's Avatar
wow that is one dirty head. http://www.sa-motorsports.com/diyport.aspx I found that helpfull. Definitely get a hold of those bits. Don't make the ports larger though. So far nice cleanup job. Just smoothen everything out and be careful on the knife edging.
Old Jun 10, 2008 | 08:35 AM
am I better off not knife edging the exhaust side? I was told to leave the intake side and to knife edge the exhaust side. What kind of issues can knife edging cause?
Old Jun 10, 2008 | 11:59 AM
tb_evo's Avatar
Definitely helpful bro! Thanks for the website.
Also, good job on the porting steve.
Old Jun 10, 2008 | 12:06 PM
RevMoto's Avatar
Just seemed like you cutting it out too short and flattening the bottom where it is supposed to be like a blade. Best thing to do is look as some of the pics the companies do. Headgames has shown some great examples.
Old Jun 10, 2008 | 01:18 PM
cssaddictm4's Avatar
Originally Posted by AreSTG
You should have just bought a head from Buschur, you are the suck
You should stick to your Jetta...and learn some grammar.
Ports are looking good, check out my head here: https://www.evolutionm.net/forums/sh...d.php?t=294134
for some inspiration. We took out a good chunk out of the head... Totaling 8hrs of porting work and 400$.
Old Jun 10, 2008 | 01:21 PM
StevenStarke's Avatar
if u want, send me the head and i'll flowbench it for ya
Old Jun 10, 2008 | 03:32 PM
RevMoto's Avatar
Curious to what bits you are using? I only use sand paper bits so I can go slow and take my time since it is aluminum. I know a lot of the major head shops use carbide bits but it seems to cut way too fast for me.
Old Jun 10, 2008 | 04:46 PM
I used a carbide bit VERY briefly on a couple spots on the exhaust ports but I basically just use the sand paper rolls on anything aluminum.
That might be something of interest... Pm me a price if you dont mind. TIA
Old Jun 10, 2008 | 05:26 PM
Yeah Im about at the 3hr mark now and can easily see hitting 8 before Im done. Did you ever have your head flow tested and is your car back together now? If so what were the results?
Old Jun 11, 2008 | 02:07 AM
No unfortunately my head was not flow benched. Just received my intake mani back yesterday, and the motor started going back in...Results soon
Old Jun 11, 2008 | 08:30 AM
Sweet. The project looks good so far.. Im not on here much but Ill try and check back on it from time to time.... Im really interested in your results.
ssteve
Nov 17, 2008 04:24 PM
ssteve
Nov 14, 2008 01:08 PM
ultimatesteve
41
Nov 4, 2008 10:23 AM
ultimatesteve
19
Aug 25, 2008 10:13 PM
ultimatesteve
Feb 24, 2008 01:14 PM
