28psi on stock motor and stock turbo?
Old Jun 10, 2008 | 08:14 AM
jcsbanks's Avatar
Originally Posted by supersilverMR
You should only run around 22psi on 91-93 pump.. After 22psi your stock turbo cannot effectively make power without knocking. You may pick up 25 or 30hp, its not worth the 7k you woud have to spend to buy a new motor. You will also want to replace your head studs. Look up a volumetric efficency chart for the stock turbo on 91-93.
At moderate flows (ie midrange, high boost) the 16G big compressor map has a nice big hump of decent efficiency that extends to a PR of about 3.3 IIRC, allowing for at least about 2 bar (29 PSI) once you account for losses between the compressor and the inlet manifold. The exhaust manifold pressure certainly isn't sufficient to push open a weak wastegate in the midrange at this level. Agree with you at the top end, and agree it is probably too much in the midrange for safety on modest octane on the stock internals, but not because of the efficiency of the stock turbo in the midrange.
Old Jun 10, 2008 | 09:12 AM
92gsxbaltimore's Avatar
22psi is deff not the limit of making power without knocking on the stock 05 turbo, but without a tune it is like Russian Roulette.
Old Jun 10, 2008 | 09:20 AM
TURBevO8's Avatar
True. My car runs 24psi peak on 93 octane with a 10.5 hotside (making my '04 turbo a '05 basically). That is where Chris at AMS set it because it was safe and knock free to that. Of course with the 272s it tapers off.
28psi without meth though is just crazy. And one thing I will add that I didnt see anyone mention (while I was just skimming) is when he gets tune/meth/pump, get head studs as well for that much boost!!!
Old Jun 10, 2008 | 09:27 AM
EvoBroMA's Avatar
lifting the head never hurt nobody?
Old Jun 10, 2008 | 09:29 AM
MR Turco's Avatar
this coming from the kid with a 21psi tune.
Old Jun 10, 2008 | 09:34 AM
TURBevO8's Avatar
He is asking a question here.
So to answer I guess I would say that yes lifting the head enough will cause a blown head gasket and there are many idiots who ran way too much boost and had this happen and that does "hurt".
Old Jun 10, 2008 | 09:41 AM
MR Turco's Avatar
Yes, he is asking a rhetorical question, and i was just messing with him. I <3 teh dextors.
Old Jun 10, 2008 | 06:50 PM
Wayne99gsr's Avatar
Originally Posted by fugiwara
28psi is too much for stock motor and turbo, unless you run meth. Upgrade fuel pump is a must! I hope you have one already.
If you are scare to break the motor, why would you want to run 28psi on stock motor?
No..... all I asked was its OK to run 28PSI? its SAFE? I never said I want to run that high.
Old Jun 10, 2008 | 06:55 PM
housedj's Avatar
use common sense. stock parts are designed for stock boost. when u go above & beyond, u best start a collection jar to replace broken pieces. i run 30psi on stock turbo/motor but its not a daily & i'm tuned for racegas only...
Old Jun 10, 2008 | 07:18 PM
1slowevo's Avatar
never a bad thing
he is still faster than you at the track
you just love his hair
you can run the 28psi, on pump (93oct)? might be a little high, (91oct) NO!!
But,why not run that high? the car is more fun at high boost just tune it accordingly with the proper setup (meth, race gas, etc)
on a good condition stock motor, you can run high boost (27-30) on a stock turbo with no ill effects for a while as long as the ecu is tuned properly. I ran 30+psi on a VIII turbo, then IX turbo and finally a 3065 all on a stock block for well over 3 years and 30k miles.
Old Jun 10, 2008 | 11:49 PM
DIDYSIS's Avatar
Friend runing 31LBS on meth
:-) Over 400 AWHP, with tune.
Old Jun 11, 2008 | 12:24 AM
dbsears's Avatar
Am I the only one seeing he is running 28lbs on only pump gas. Not Meth like everybody is saying they do. He also lists no tune. If anybody thinks you can run 28lbs on stock tune on strait pump is nuts...especially on VIII's. Considering you are in WA you probably run 92octane like the rest of us.
Old Jun 11, 2008 | 08:10 AM
EvoBroMA's Avatar
I was played with my Apex'i AVCR for a little. and turned up the boost to 28psi.(it was at 21psi) the car pulls alot harder on the top end.
so you're only asking if it was safe... but you did it anyway?
Old Jun 11, 2008 | 10:39 AM
1slowevo's Avatar
thats what I did on 100oct on stock turbo at 32lbs
you're not the only one
a little late
Old Jun 12, 2008 | 12:07 PM
evoPirate's Avatar
get some headstuds, a bigger fuel pump and injectors, E85 and a tune, you can run 28psi all day!
