Cam lift and Rocker Ratio
What is the rocker ratio on the Evos? Im trying to figure out lift at the VALVE. For instance the Cosworth M3 intake cam has a lift of 11.6mm witch is .456 in inches...so if the rocker is a 1.5 ratio then .456 X 1.5 = .685 lift at the head? Or is the 1.5 already configured into the spec .465/11.6mm at the head?
oem rocker ratio is 1.73:1
advertised valve lift is figured in using the ratio of the rocker, since the rocker helps to open the valve.
to figure lift of a particular cam, measure the tall portion of the cam lobe, subtract the narrowest portion of the cam lobe (base circle) = cam lift * rocker ratio = valve lift....minus any lash, which can vary due to cam maker & cams that are hydraulic or use mechanical adjusters
Thanks Amigo..I was just wanting lift at the head. Wanted to see what the number was...Im a domestic fella so I want to know what LIFT my M3s were
456 doesnt seem like that much...but it probably is considering the motor size
Boomba Racing
Jul 7, 2014 01:08 PM
Dynotech Tuning
EvoX 'For Sale' Engine Internals and Drivetrain
21
Jan 17, 2012 05:34 PM
Gary@MellonRacing
Evo 'For Sale' Engine Internals and Drivetrain
Sep 25, 2010 04:01 PM
