kinda curious
Old Jun 14, 2008 | 12:26 AM
dsmdeliveryboy's Avatar
kinda curious
Ok so I'm looking at getting a 06 evo ix and it already has the apexi tbe and intake, i want to get cams and a boost pill for 26 psi but what size injectors will i need and will the stock ix bov be able to hold that boost? o ya and a flush
Old Jun 14, 2008 | 12:13 PM
still curious
Old Jun 14, 2008 | 12:27 PM
Warrtalon's Avatar
A boost pill? Errr.
You won't need injectors, and the stock IX DV will be great. This is information easily gleaned through searching.
Old Jun 14, 2008 | 12:34 PM
So I wont need injectors to run 26psi? And I thought the stock DV only holds 25.5 psi?
Old Jun 14, 2008 | 12:40 PM
Warrtalon's Avatar
It's not like it suddenly falls apart 1 psi over its max efficiency. The stock plastic BOV is only efficient to 13psi, but Evos run 19-20 from the factory. You probably never even noticed, right?
It's also not like you'll be seeing 26psi for very long - maybe just for brief moments (seconds or less), because we only spike for a moment then fall.
Injector size is not determined by psi - it's determined by how much fuel you're flowing of which psi is a determining factor, but only one of many.
Old Jun 14, 2008 | 12:45 PM
EvoBroMA's Avatar
what about his flush?
Old Jun 14, 2008 | 12:46 PM
So then I wont need to spend money on injectors and a fuel pump? I can just throw in the cams and boost pill and get a tune and ill be fine?
Old Jun 14, 2008 | 01:07 PM
Warrtalon's Avatar
I didn't say anything about not needing a fuel pump - you never mentioned it at all. It's an absolute necessity.
I don't why you keep talking about this boost pill thing. Get a boost controller if you want to control boost. If you want the ECU to control boost, then you let your tuner do it all.
Old Jun 14, 2008 | 01:11 PM
Well the boost pill is just something bryan @GSTmotorsports had talked to me about, but I could go with the hallman pro.
Old Jun 14, 2008 | 01:12 PM
2highpsi's Avatar
Old Jun 14, 2008 | 01:24 PM
How is that funny? He meant to say flash*
Old Jun 14, 2008 | 01:28 PM
Warrtalon's Avatar
That's something where Bryan would provide it and do a special tune for you that utilizes it. it's not a standard thing in the community that people buy, put in, and have someone else tune it. Just realize that very few people do that, so it's not a common term used here when referencing "mods." Bryan knows what he's doing, though, so you should be asking him all these basic questions if he's going to be your tuner.
It's funny, because YOU'RE the one who typed "flush" in the first post. Funny stuff...
