Fuel pump options for E85
Old Jun 16, 2008 | 10:46 AM
Aby@MIL.SPEC's Avatar
I am possting this question here, as i may get more constructive advice on how to accomplish my goals......
california 91 octane is ~$4.90 / gal & a e85 station is now opened up down the road close by......so i will be changing fuels soon. maps will change, as i tune my own aem...no problem.
I currently am running a fp-grn using 880cc injectors, all the basic bolt ons....
I read about upgrading fuel pumps to double units, run a higher fuel pressure regulator, etc.....
whats really necessary & what are people getting away with?
I dont plan on trying to make 1000000whp or anything like that, i just want to maximize what i have avaialble to me @ a reasonale means.....
are there any mods that i can do to my existing walbro to get more flow out of it or should i just get larger injectors & Or get a 2nd fuel pump?
money is tight, as i am try ing to get into a house soon too.
all constructive advice is appreciated......thanks
Old Jun 16, 2008 | 10:49 AM
AWD Motorsports's Avatar
double pumper is mandatory to make 400-450whp on e85 safely.. ill let you know more this week as we push our IX turbo car on e85 to 450+..
Old Jun 16, 2008 | 11:29 AM
SloRice's Avatar
Dual fuel pumps and 1000cc injectors. SPIN2GST's car was running like that all last year.
Old Jun 16, 2008 | 12:30 PM
jmartinez1170's Avatar
Dual pumps 1200cc's if you run anything higher then a 35R i would look into dual rail setup with 1000cc's as the main spraying injectors then 880cc's once it hits a certin rpm and boost level. Good luck. With your goals.
Old Jun 16, 2008 | 12:40 PM
MO_EVO8's Avatar
I was told a modified 255lph and 1200cc is enough for 400-550hp
Old Jun 16, 2008 | 12:41 PM
mdsevo06's Avatar
Aby, is that the shell station in Carlsbad? I was just talking to James about this on Friday and will be going E85 mid July. Closest to me is the Ford dealer on Elcajon and the 15. I have a 255 and James will be ordering me a set of RC 1000's, but I'm on a stock IX turbo. You could get away with the single 255, as long as you don't turn up the boost to much. Are you going with a GM 3-port?
Old Jun 16, 2008 | 12:51 PM
MO_EVO8's Avatar
Also to be more accurate you can whatch your injector duty cycles, if you currently have a AEM. And get a idea due to the E85 requiring 30% mroe fuel. And like mdsevo06 said it dose make a difference on what turbo and ect. you are running. Good luck
Old Jun 16, 2008 | 03:58 PM
lan_evo_mr9's Avatar
1000cc's and a 255 walbro not enough for a normal 9 turbo with bolt-ons and stock ecu on E85? I know he has a green but I was just wondering for myself. Sorry to but in.
Old Jun 16, 2008 | 04:03 PM
evoPirate's Avatar
I dont know if you'll absolutely require the double pumper. Ask Lucas English what his set up is, he's hitting over 450 on a IX turbo and E90.
I have a 255 and 1000cc's on an 8 turbo, and I'm only at like 65% duty cycle, maybe a hair less. 880's for sure won't be enough, 1000 might, 1200 for insurance though. Toss those in and start tuning on the 255 and see what the duty cycles are before you drop the cash for a double pumper system
Old Jun 16, 2008 | 04:08 PM
good call. I'm "only" going to run about 26psi. Not looking for the crazy power.
Old Jun 16, 2008 | 04:09 PM
I got a set of 1000's already. Pirate- what other mods do you have?
Old Jun 16, 2008 | 04:26 PM
evoPirate's Avatar
ex mani, CAI, TBE no-cat, walbro, forge UNOS, Dejon 1G BOV, U/LICP, turbo XS FMIC, 1000cc and E85. Stock turbo, stock cams
Old Jun 16, 2008 | 04:29 PM
dsmfan95's Avatar
Aby, you can probably push the single pump to 450whp (DJ) no problem. I am pushing a little over that and found a deal on the double bumper so I upgraded.
Lucas is making 500whp on a single pump if that says anything.
Old Jun 16, 2008 | 04:30 PM
M3EvoBR's Avatar
You don't need dual fuel rails. Here in Brazil we run ethanol on the streets for at least 20 years ...
If you look for big numbers and have an AEM go for 1600 cc or 1200 cc and dual 255.
Everything will be perfect.
Old Jun 16, 2008 | 04:50 PM
Pirate- have you dynoed your car? If so, what are the numbers looking like?
