tranny starting to go
Old Jun 17, 2008 | 08:11 AM
sub12anyone's Avatar
So Ive had a bit of a 5th gear grind for a little. I replaced my tranny fluids and still noticed it. Then just a couple days ago, out of no where Im having huge problems getting into 1st and reverse. None of the shifts are remotely smooth. I have to shove it into gear, hard. The cars at about 52,500 miles and I never race it so this is highly unexpected. Honestly, Ive spent ludicrous amounts of money maintaining this car and if the tranny is about to go, so is the car unfortunately. Any ideas?
Old Jun 17, 2008 | 08:12 AM
TeStUdO's Avatar
What fluid did you use?
Old Jun 17, 2008 | 08:34 AM
gsrboi80's Avatar
1200 rebuild in you future
Old Jun 17, 2008 | 08:48 AM
regular diaqueen
Old Jun 17, 2008 | 08:52 AM
gsrboi80's Avatar
I hope not the Diaqueen LSD gear lube. If you using Diaqueen in your tranny it better be the MR Specific 80 dollar stuff. That regular LSD Diaqueen should only be used in your TC/Rear Diff
Old Jun 17, 2008 | 12:00 PM
krazirob's Avatar
yeah mine has started doing that but only at high rpms.....could it be safe to say that its my clutch that needs to be replaced??
because i actually have an appt with TTP to replace my clutch tomorrow with the Exedy HD so i wasnt really worrying..........
Old Jun 17, 2008 | 12:28 PM
my exedy twin disk has like 12k on it and holds fine. its the other tranny parts that are now the reason im selling this car.
Old Jun 17, 2008 | 12:30 PM
number 8's Avatar
Sounds like clutch.
Old Jun 17, 2008 | 03:10 PM
krazirob's Avatar
^^are you referring to me there number 8......?? or the OP
Old Jun 17, 2008 | 03:43 PM
waitin4d's Avatar
It had a similar problem when my clutch was going.
I has to shove into first and reverse.
After replacing the clutch, it is fine.
Old Jun 18, 2008 | 08:37 AM
The clutch doesnt slip at all though and its an exedy twin disk with only 12k like I said. I only have like 380-400 whp. Never ever race. And ive been driving the car for over 4 years.
Old Jun 18, 2008 | 08:50 AM
thatguy's Avatar
Have you tried to adjust the clutch pedal?
Old Jun 18, 2008 | 09:10 AM
m98evolution's Avatar
How about the underhood bushings above the tranny? Read that the rubber bushings get mushy after several years.
I also read that another owner noticed his linkage was misaligned (it had pivoted off bolt--not parallel to bumper) so an adjustment fixed it.
Old Jun 18, 2008 | 11:59 AM
krazirob's Avatar
good point.....linkage bushings are not much to install.....ill try that myself
Old Jun 18, 2008 | 03:31 PM
03Cobra2Evo's Avatar
hmm 52 k huh
