Coolant Leak
Old Jun 17, 2008 | 02:35 PM
JeffMas1587's Avatar
Coolant Leak
I was driving around today kind of pushing my car but nothing to crazy. I noticed that my car was running very hot all of a sudden, so i pulled over and turned her off. As soon as i did that i noticed a lot of smoke coming from the hood vent. i popped the hood and even more came out. i could see green coolant all over the inside of the motor. it was all over the hood and even pooling on the intake manifold. i check all the visible lines i could and i cant find the leak. the lines running into the firewall are all good and looking for a good 20 minutes found nothing. i havent started the car since then and i had my car towed back to my house. any ideas where to start?
Old Nov 10, 2008 | 11:33 PM
sikrsix's Avatar
Bringing this back from the dead since this just happened to me tonight!!!
Any ideas?
Old Nov 11, 2008 | 01:30 AM
sikrsix's Avatar
Bump since my car is my DD and i cant drive it till its fixed.
Also radiator was ice cold, and no heat.
Old Nov 11, 2008 | 07:39 AM
barneyb's Avatar
Stuck thermostat
Old Nov 11, 2008 | 07:46 AM
robogast's Avatar
check freeze plugs
Old Nov 11, 2008 | 08:07 AM
i had a hole in onen of my hoses coming off the block to the intake manifold. there was a one inch slit on the under side of the hose that took me for ever to find
Old Nov 11, 2008 | 11:25 AM
sikrsix's Avatar
Just popped off my radiator cap and it looks bone dry! Did pressure build until finally a hose popped off or at least vented pressure? I tugged on all the hoses I could physically reach and they all seem to be still intact. (didnt check for slits yet, waiting on a friend so i can start the car and he can look for a leak.
Old Nov 11, 2008 | 12:00 PM
evo_glasses's Avatar
That is pretty much it though... No real diagnostic... more of a visual thing if you have a leak like that... Get a car manual and check over the whole system visually...
Old Nov 11, 2008 | 01:50 PM
sikrsix's Avatar
Found it and fixed it. About a 2" slice on a line leading from the block to my throttle body. Wasn't rubbing on anything, so no clue how it happened, but its fixed!
WickedWhiteDemon
Jan 25, 2014 08:29 PM
BoosTyEVO
Apr 19, 2013 06:31 PM
naucrx
25
Jun 28, 2007 02:11 PM
EvilDylan
Oct 13, 2005 09:50 AM
SilverEvo8owner
Jun 2, 2005 08:55 PM
