Manual Cut-Out ?
Old Jun 17, 2008 | 04:29 PM
beemerfreak's Avatar
Manual Cut-Out ?
Where would be the proper place to weld this manual cutout?
http://www.jegs.com/i/Granatelli/467/3007502/10002/-1
I'm plaining to have it welded on my test pipe. Should I go a different route?
Old Jun 17, 2008 | 05:05 PM
wreckless969's Avatar
o2 dump? Isnt that the same thing?
Old Jun 17, 2008 | 05:08 PM
selp's Avatar
Originally Posted by wreckless969
o2 dump? isn't that the same thing?
no, that would be attached to the o2 housing, the cut out should be attached at the downpipe, so cutting and welding will be involved.
Old Jun 17, 2008 | 05:09 PM
EvoBroMA's Avatar
on the test pipe is probably the most convenient. if you run a cat you have to have it put in the down pipe.
Old Jun 17, 2008 | 05:15 PM
Well I mean isnt it the same effect?
If not can you run both?
Old Jun 17, 2008 | 08:02 PM
Makes sense.
I did some research and some had cutouts welded on there DP. But they also mentioned they were running the stock catback.
Thanks.
