Autometer Wideband
Old Jul 17, 2008 | 06:52 PM
scottatyamaha's Avatar
Either your wideband is off your car is a ticking time bomb. At what part of the exhaust did you put the sensor?
Old Jul 17, 2008 | 06:55 PM
Jp7's Avatar
Jp7
I have a megan downpipe, megan midpipe (resonated) and megan catback.
The megan catback has a bung in it so I used that (similar to where the stock secondary sensor is)
the stock secondary sensor is in the bung in the catback.
Old Jul 17, 2008 | 06:59 PM
That is way too far back for that sensor, it needs to be right about 18inches from the turbo.
Old Jul 17, 2008 | 07:10 PM
Jp7's Avatar
Jp7
see my other post...
https://www.evolutionm.net/forums/sh...light=wideband
pics in there of the install...
Old Jul 17, 2008 | 07:30 PM
Well its a little too far back and at a bad angle
Old Jul 17, 2008 | 08:33 PM
andrewzaragoza's Avatar
Originally Posted by Jp7
why would I need to log it if i can look with my eyeballs and see "10.0"?
I bought a wideband so that, for now atleast I could see if there was any problem in my AFR.
well an afr of 10 is too rich. loggin would help u get an idea on how the car is running and if its way back and its still that rich then there is something definitely wrong. the further back the wideband the leaner it tends to read.
Old Jul 17, 2008 | 08:36 PM
Jp7's Avatar
Jp7
The car seems to be running fine... why would AMS have tuned it that rich? I was only tuned last month and I havent done any other mods since then but install this gauge.
Old Jul 17, 2008 | 08:44 PM
ams is a great shop. just trying to help u figure out why the afr is showing 10s. well i guess if u know someone with a bosch wideband sensor then u could try that and see if ur sensor is band.
Old Jul 19, 2008 | 11:04 AM
gsrboi80's Avatar
Free air calibrate the sensor and get it logging by pinning the analog output into your ECU then log some pulls and make adjustments as needed
Old Jul 19, 2008 | 11:27 AM
Jp7's Avatar
Jp7
There is no such thing as logging or calibrating this sensor.
This is not an AEM wideband.
I have a better thread started on this problem:
https://www.evolutionm.net/forums/sh...d.php?t=358243
