Stock Engine FP Green 93+Meth Dyno Results
Old Jun 23, 2008 | 01:30 PM
  #31
recompile's Avatar
Warrtalon, I'm not saying that water + meth results in a higher effective octane than straight meth...
I'm just saying that, for example, a 12.5:1 mix has a higher effective octane than a 11.5:1 mix simply because there is less 93, but the same amount of meth
And yes, I would not run this aggressive tune on a road race, but I will run the same 50/50 mix, so it will be somewhat close.
Old Jun 23, 2008 | 01:32 PM
  #32
Aniel's Avatar
Very Nice
Old Jun 23, 2008 | 01:33 PM
  #33
4kinboost's Avatar
Bump for a vendor with great service.
Old Jun 23, 2008 | 01:36 PM
  #34
4DR's Avatar
4DR
lets not forget to change those plugs!!!!!
Old Jun 23, 2008 | 01:37 PM
  #35
RazorLab's Avatar
Originally Posted by Shameless Tuning
It didn't like 23° of timing ... I probably should have printed one of the other 392 pulls, but that dip is 4 counts of knock
I had a feeling, but didn't want to ***-ume.
What peak timing did you end up with?
Old Jun 23, 2008 | 01:54 PM
  #36
9sec9's Avatar
I kind of suspected something other than boost too, but at that RPM, I think it's probably a combination of things coming together at that rpm. Boost falling off, timing and stock cams/manifold breathing, etc. The PERFECT STORM.
Old Jun 23, 2008 | 01:59 PM
  #37
Warrtalon's Avatar
Warrtalon, I'm not saying that water + meth results in a higher effective octane than straight meth. I'm just saying that, for example, a 12.5:1 mix has a higher effective octane than a 11.5:1 mix simply because there is less 93, but the same amount of meth
Yes, but then that takes us right back to the question of why you want to run water at all. You can run 12.5:1 with 100% meth just as well as you can with 50/50, but with the 100% meth, it would give more power. You said you were running water so that you could put in less fuel and thus have a higher effective octane. I think you got it all mixed up.
If I'm the one confused, please someone edify me.
Old Jun 23, 2008 | 02:06 PM
  #38
alicea8541's Avatar
How much more, on average, do you think 100% meth would make over a 50/50 mix at this level of modifications? I know it will be a rough estimate.
Old Jun 23, 2008 | 05:06 PM
  #39
tony gibson's Avatar
How are you guys holding this much boost? I can only hold 21 to red line (aem reading) and trapped 123mph....if i could get the boost up...
Old Jun 23, 2008 | 05:15 PM
  #40
RazorLab's Avatar
Ecu-boost and a good actuator.
I've seen anywhere from 24psi to almost 26psi at 7600 rpm.
Old Jun 23, 2008 | 05:43 PM
  #41
recompile's Avatar
I went with 50% water for cooling capacity, especially at road courses. Pushing a small turbo to the edge of its efficiency results in hotter air.
I merely stated after the fact that I can still get a high octane benefit from the meth because I don't need to add fuel to keep temperatures down.
Warrtalon, I understand where you and others are coming from... I respect the fact that 100% meth can make more power than a 50/50 mix... but my point is, the injection system can be used not only for power but for cooling capacity and safety... which is what I've opted to do since the car will be road-raced.
As cool as it would be to run a few more degrees of timing on a single dyno pull or a single pass on the quarter mile, the reason I've added the kit is to run 50/50 mix, and to get the combined benefit of more octane and more cooling capacity.
Old Jun 23, 2008 | 05:45 PM
  #42
Warrtalon's Avatar
It's not registering. The cooling effect is outweighed by the octane. You can make more power with the 100%, or you can make the same power with lesser timing/afrs. You said this tune/boost was NOT going to be used on the road course, so that's what I'm confused...
I ran HPDE and time trials the last 2 years at a high level on 100% alky - no need for water. Just letting you know...
Old Jun 23, 2008 | 06:45 PM
  #43
codean's Avatar
Do you guys think upgraded rod bolts would be worthwhile at this power level?
While some of you think the water serves no purpose, there is the fact that at 50/50 the mix is no longer a big fire hazard. Also, I think that the whole water vs methanol has more to do with correct tuning for what mixture you are running. It's easy to tune for 100% methanol. However if you use that same tuning style for 50/50 or 100% water, you will make less power.
Old Jun 23, 2008 | 06:53 PM
  #44
Ph3n1x's Avatar
Nice, looks like 124-125mph traps now and still no cams.
Any reason for the 50/50? You can make more power with 100%, and there's not much reason to run a water mix.
Methanol pumps on some kits don't like 100% mixtures as they eat away on the pump diaphrams.
Old Jun 23, 2008 | 07:13 PM
  #45
mudduck's Avatar
^^^ yeah, my AEM meth kit manual recommends no greater than 50/50...
So that's why I'm running 75% meth/25% water ---> to make more power!!!!!
