Help, engine shot dawn
Old Jun 26, 2008 | 09:47 AM
nazzal's Avatar
Unhappy Help, engine shot dawn
i have this proplem now for the last two week, when i remove my feet from the thurotal or brake the car engine will shotdawn and i have to wait for some time to restarted again.
I have change the fuel bamp and clean the thurotal but it the same proplem i relay don't find what rong with this car?????
can any one help
my car ir evo 8RS
Old Jun 26, 2008 | 10:27 AM
StevenStarke's Avatar
you mean throttle right? i imagine from where your location is, you dont speak english very well. let me see if I can help:
what modifications do you have to your evo?
If your car is shutting off, you must be losing air, fuel or ignition. maybe a boost leak?
Are you sure the fuel pump is installed correctly?
If you can, make a video of the car doing what it does so we can see it a little better.
-Steve
Old Jun 26, 2008 | 11:54 AM
Chemwarrior's Avatar
Who's Dawn and why did your engine shoot her? LOL.
Old Jun 26, 2008 | 02:53 PM
nazzal's Avatar
Steve you are right am from Qatar where english is second language and cars is first language
about the modifications:
wollbro fuel pump (new)
Greedy Air Filter (new)
i have check the fuel line from the tank to the engine every think look right, i will do check to the air filter since it also fixed recently.
fuel pump is installed correctly am sure.
Chemwarrior am sorry i mean by shotdown than the engine stop not runing
Old Jun 26, 2008 | 03:01 PM
filter's Avatar
Put your old fuel pump back in and see if it does the same thing. you might of got a bad fuel pump.
Old Jun 26, 2008 | 03:10 PM
nazzal's Avatar
Filter i have change the fuel pump after i have this problem
Old Jun 26, 2008 | 06:42 PM
Turbodemon's Avatar
i just had the same thing happen to me last week. for me the intercooler hose that connects to the throttle body kept sliding off because of bad hose clamps. this caused the car to leak and shut off. i would check all your intercooler hoses and clamps make sure that is ruled out since it is probably a common thing amongst evos.
Old Jun 27, 2008 | 02:29 AM
yikez's Avatar
check your intercooler piping .. you might have a boost leak.
as suggested before, put back your old fuel pump and see it is still does it.
Old Jun 27, 2008 | 05:22 AM
I knew what you meant. I was giving a bad attempt at humor. I have some friends in Qatar.
Old Jun 27, 2008 | 02:39 PM
nazzal's Avatar
I have feeling this problem might be related to the ECU what do you think?
am sorry for keep asking but hear in Qatar we do not have any specialist on evo's
Old Jun 28, 2008 | 04:33 AM
Rainwarrior's Avatar
nazzal
1st check your intercooler piping
2nd it may happen if you are using hks SQV (Blow off valve)
3rd check your airflow senser
Good luck
