New FP White turbo
Old Jun 28, 2008 | 12:05 PM
  #91
EVO8LTW's Avatar
Old Jun 28, 2008 | 01:09 PM
  #92
speedy evo's Avatar
the turbo sounds like a pretty good deal to me.
Old Jun 28, 2008 | 02:58 PM
  #93
Liqquid's Avatar
Originally Posted by EVO8LTW
hmm, looks stout
Old Jun 28, 2008 | 03:15 PM
  #94
Jeff_Jeske's Avatar
Well...... For $600 this does seem to be an excellent deal.
I would imagine that most of us will wait to see how it does at high boost on race gas. That should be an easy test for FP. So lets see the results!
Old Jun 28, 2008 | 04:24 PM
  #95
hytek369's Avatar
Originally Posted by supersal
TK thanks for leaking it man, now everybody knows theres a "FP White"
Surely thats a good thing for Robert, he's even agreed to take orders and put them out there already... (Robert we read all your posts white, green, red people wana buy them man)
Only thing is that Robert was still in the process of testing so people must understand he wasn't ready to release the results yes.
So Far what we know for Sure:
- Evo 9 Based Turbo
- HTA 68 Compressor Wheel
- Flows more Air than the Stock Evo 9 16G Wheel
- Does not use the Larger Green Turbine Wheel
- Option of a FP Uprated Actuator if you like
- Cheaper than the Green
good summary
Old Jun 28, 2008 | 05:31 PM
  #96
teamspink20's Avatar
def cant wait to see results
Old Jun 28, 2008 | 05:33 PM
  #97
TKEVO's Avatar
Veteran: Air Force
Old Jun 28, 2008 | 05:35 PM
  #98
TKEVO's Avatar
Veteran: Air Force
- Evo 9 Based Turbo
Thanks man. I didn't know a leak about a new turbo would be bad... So yea you basically have everything down and of course people are going to want to see the numbers after they finish testing them.
Old Jun 28, 2008 | 05:54 PM
  #99
evo_gerard's Avatar
i'd like to see a dyno sheet with the white vs. the green at 22-23psi on pump gas. cuz for me that will be the decider on which turbo to go with. i don't plan on runnin any thing other than pump gas (no meth or race gas) and i only want a max of 22 or23 psi.
Old Jun 28, 2008 | 05:57 PM
  #100
TKEVO's Avatar
Veteran: Air Force
I'm the same way but I'm leaning more towards the green at this point because I will be running meth.
Old Jun 28, 2008 | 06:00 PM
  #101
Indy Evo's Avatar
That white rabbit does not look like the one I saw today.
Old Jun 28, 2008 | 06:04 PM
  #102
Tarmacisback69's Avatar
im waitin for the turbo that bolts right on, stock like spool and puts out 500whp on meth....for 1200! but hey we can all dream.
but back to reality, is this going to be better then the green? or between the ix turbo and green.
tmisbk
Old Jun 28, 2008 | 06:06 PM
  #103
Liqquid's Avatar
sometimes they have spots and the ears are longer
Old Jun 28, 2008 | 06:07 PM
  #104
apagan01's Avatar
why would yo say that we havent seen enough evidence of this new FP White on race gas and meth, in my case id like to se it on race gas since thats what i run ,,,, give it some time and let others test her on those different parameters
Old Jun 28, 2008 | 06:23 PM
  #105
TKEVO's Avatar
Veteran: Air Force
They said that it didn't flow as much as the green does. The white is in the stage between the IX and green. The white is going to have a faster spool but the green has a better top end. FP told me that it prob won't make as big #'s in HP as the green. Yea I will still like to see the numbers but if they are coming out with a turbo that might be "Better than the green" wouldnt you think it would cost a little more anyways?
IDK I guess FP just told me that so I can buy the green. Yeeaaa I think not.
