Unstable AFR at low throttle
Old Jun 28, 2008 | 07:13 AM
W2J's Avatar
W2J
Originally Posted by Toxin
Care to elaborate on that?
Lean Spool Disable
Why?
When in open loop operation, the factory ECU artificially leans the fuel mixture by about 1 full ratio point which can cause difficulty in tuning for proper AFR. Disabling "Lean Spool" will also allow for your map AFR numbers to more closely align with your actual measured AFR.
https://www.evolutionm.net/forums/sh...d.php?t=261465
Old Jun 28, 2008 | 07:25 AM
Toxin's Avatar
Thanks, I'll speak with 4WS to see what we can do about this. I don't think I'm up to this
Old Jun 30, 2008 | 07:29 AM
Toxin's Avatar
Well after discussing it with Tamer, lean spool has nothing to do with it. Anyone else has an idea of the cause?
Old Jul 15, 2008 | 07:24 PM
W2J's Avatar
W2J
^ maybe tamer should try it worked for many.
Old Nov 11, 2008 | 06:33 PM
EVIL MR's Avatar
Mine does that same thing Fluctuating afr during cruise lets say I am going 55 in 5th at steady rpm it will be fine for a bit until it will start going between 12.5 & 14.9 very fast, now I can stop that by giving it a little more gas and then it will steady again if I don't give it more gas it will give code 0134 saying that the front o2 sensor not working. I even disconnect the front sensor at the ecu and using zeitronix NBS at 14.7 and other values for better gas mileage. Again if I get my foot off the gas and on again it will start to jump and give the same code. my wide band is very new.
Old Feb 1, 2013 | 05:11 PM
CRONZ305's Avatar
resurrection !!!
find out the problem at all??
Dr. Jekyll
Apr 1, 2016 08:42 AM
black_out
Aug 2, 2014 05:28 PM
Anubis18
Sep 20, 2013 02:39 PM
nj1266
125
Jan 12, 2010 07:37 AM
