HELP: Turbo timer install
Old Aug 17, 2003 | 04:00 PM
kdogmk133's Avatar
I followed the directions given in this board and it is still not working. I had an eclipse before this and had the same turbo timer and had no problem installing that one.
I have an HKS type 0 turbo timer with a 95-99 eclipse harness...
I hooked up the harness fine, i grounded it, tapped into the parking brake and tapped into the rpm wire (i think it was the right one - brown and green wire on first harness, 4th wire). If someone could come back to me on any ideas i might have overlooked i would appreciate it. Thanks a lot...
MIKE
Old Aug 17, 2003 | 05:06 PM
kdogmk133's Avatar
Nevermind.. solved. The parking wire clamp thing that comes with the kit didnt slice the wires, so the TT read that the E-brake was down and shut off the car.
Works now, so you can delete this post if you like. Thanks.
MIKE
Old Aug 17, 2003 | 05:18 PM
3K's Avatar
3K
That's the same thing that happened to me, that POS wire splice that comes with the TT (have an Apexi by the way) didn't slice the wire either, but instead of shutting the car off, mine wouldn't shut the car off with the e-brake down.
