Evo ix T Case
Old Jul 4, 2008 | 05:07 PM
AWD Motorsports's Avatar
Originally Posted by 94AWDcoupe
The 2005 8 has ACD just like the 9. So yes it is identical. The ring and pinion is identical as well in all t-cases. And the early cases without acd break less often than the ones with ACD. at least around here they do. I have seen a bunch of broken acd cases. I have only seen one broken 2 spider diff early case. maybe it just means no one around here is racing the early cars.
So the original poster asked if 9 cases are stronger than 8. I would say most definately not. they are the same.
I believe the lsd causes more breakage due to having more hook on the line. The weaker two spider front diff breaks less because it allows the front tires to spin more. thus acting like a fuse in the drive train.
yes i am aware all ring and pinions are the same and yes the VIII ACD is same as IX.. yes i know all that i guess my 1st post should have been completey thorough..
And sorry i disagree that the ACD cases break more often.. in your area maybe not but in my area the VIII cases break more so i will say the IX Tcase is stronger " In my opinion"... also, according Shep spinning isnt the answer for not breaking.. I went thru that when i broke a brand new tcase spinning on DOT's 2nd pass.. I have an RS diff tcase that has 20+ hard slick runs w/o issue now..
ITOzann
Sep 20, 2016 04:55 PM
OZboyee
Oct 18, 2015 09:37 PM
MisUnderStood
22
May 28, 2015 08:17 AM
jacked cobra
36
Apr 26, 2015 05:36 PM
Blue91lx
May 23, 2012 06:05 PM
