Magnus Intake
Old Jul 6, 2008 | 07:51 AM
  #46
EvoIXJDM's Avatar
Thank you very much for ALL your comments and help!!
I am really happy ehhhhhhhhhh jeje
Oks lets install it and will I post the results!!
Thanks again!
Old Jul 6, 2008 | 07:55 AM
  #47
EvoIXJDM's Avatar
Old Jul 6, 2008 | 11:45 AM
  #48
92gsxbaltimore's Avatar
Originally Posted by zbomb
Dude, I'm sorry but get a clue. Don't you think they would have made more of them if they were any good?
To the OP, Did Magnus ever answer your email?
did you read the post from BrianH?
Old Jul 6, 2008 | 01:09 PM
  #49
CO_VR4's Avatar
This manifold is VERY similar in concept to the HKS formula car manifold design. It is also extremely expensive to manufacture, compared to the usual SMIM.
Don't assume that the number made has anything to do with whether they work well or not...
Old Jul 6, 2008 | 05:26 PM
  #50
zbomb's Avatar
Yeah Dude, I was just wondering if the manufacturer actually answered the email the OP sent... Does Brian work for Magnus as a Cust. service Rep?
COVR4...Your right I should'nt assume....
Old Jul 6, 2008 | 06:04 PM
  #51
03whitegsr's Avatar
I don't know if I would say "VERY similar."
The two manifolds use distinctly different methods behind there inlet configurations. The HKS actually uses a controlled cross section that forces the pressure distribution across the plenum to be nearly a constant. This manifold makes an attempt at distributing the air more evenly then a more conventional side feed inlet. Driven Innovations manifold does something similar by offseting the plenum on the runners.
Beyond that, the HKS manifold also features ITBs, dual injectors designed to provide better atomization at high engine speeds, tapered runners, and I'm sure some other very well engineered design aspects that are less obvious. Comparing this manifold to the HKS manifold is quite the stretch.
Old Jul 6, 2008 | 07:53 PM
  #52
AznEvoIX's Avatar
*grabs popcorn*
Old Jul 6, 2008 | 09:25 PM
  #53
EvoIXJDM's Avatar
I am at home in the week end, monday I will check the email at my office, maybe Marco already answer me.
Old Jul 6, 2008 | 09:43 PM
  #54
CO_VR4's Avatar
Not at all. As I said previously, the manifolds are similar IN CONCEPT. That is obvious from a comparison of their basic shapes, and the manner in which the airflow is distributed. Are there differences? Sure. The intended uses are different. However, the feature that was the topic of discussion here is readily apparent.
That having been said, the HKS is a pretty advanced solution that looks great just sitting there, don't you think?
Old Jul 6, 2008 | 09:48 PM
  #55
JC evo1's Avatar
does the hks use Butterfly's or roller barrels?
Old Jul 6, 2008 | 10:57 PM
  #56
03whitegsr's Avatar
I bow before that HKS manifold.
If only more pictures of the insides were available...
Old Jul 7, 2008 | 09:37 AM
  #57
EvoIXJDM's Avatar
No, I didnt received an answer from Marco yet....
boostzealot
Mar 23, 2010 11:09 AM
JohnBradley
Mar 16, 2010 07:27 PM
maperformance
274
May 1, 2009 03:53 PM
antilag_200
Feb 25, 2008 09:26 AM
TurboRSX04
Southeast Region
14
Jan 24, 2008 08:19 PM
